SOURCE: I cannot get the webpage to come up using the
first of all check what is the default gateway you are getting in your computer in xp go to start>run>type cmd>hit enter ,,,in cammand prompt type ipconfig........type this default gateway address in internet explorer.......if it goes to search page,,,,type the command "start iexplore gateway address "in the command prompt...If still does not open you need to unplug the power from router for 30 seconds,,,if still does not that means firmware of router is corrupted ,,you need to reset the router and then upgrade the firmware as well
SOURCE: I have a TP-Link TL-WR941ND
Can you kindly let me know the settings on your modem and router. Whether they are connected via using bridging mode or ppoe mode. In order to find this simply enter 192.168.1.1 in your browser and enter user id as admin and password as admin and hit enter. In advanced lan settings just click on first right hand side edit button and click next and see wether ppoe is selected or bridging is selected in order to ascertain the ip of wifi modem simply click on start button when connected to internet via wifi modem and select run type cmd and hit enter in the black window type tracert www.google.com wait for few seconds the first ip in the list will be your modems ip. use the same method as described above to find which way is it connected to server bridging or ppoe.
SOURCE: I can't log in to TD-W8901G
Reset the device and reconfigure the SSID and Security Key using this procedure:http://www.tp-linkru.com/resources/software/201161016042811.pdf And this: http://www.tp-link.us/products/details/?model=TD-W8901G
