Question about Jenn-Air JGC8536 Gas Cooktop
One of the ignitor is cracked. Do I need to replace the whole burner base?
    President:
  • 693 Answers
You do not need to replace the whole burner base you need to replace de ignitor
Posted on Sep 24, 2011
6ya staff
SOURCE:
Frozen locknut holding burner to cooktop
These frozen nuts can be a real pain, try spraying something like w d 40 or similar over a couple of days before trying to force it, best to get a ring spanner or socket that fits nice and tight.
Good luck. Ray
Apr 09, 2014 | Thermador Cooktops
The stove top seems to be clicking, but the burner won't light
A common problem with that type of ignitor is that the porcelain insulator (much like a spark plug has) can crack easily. When it does, there will be a clicking sound, but the spark no longer arcs from the top of the ignitor post to the burner and cannot light the gas. Without an intact insulator, the ignitor is effectively shorting out and needs to be replaced.
Dec 27, 2010 | Jenn-Air JGC8536 Gas Cooktop
The igniters are constantly clicking after cleaning the cooker. What can I do to stop the clicking?
This a coomon problem thaty occurs when you clean the "cooker". Residue from cleaning products may be preventing the ignitor from producing a spark (Arc) to the base of the burner. If you are able, clean the ignitor and adjust it. f you have too much space between the ignitor and the base of the burner, it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the ignitor. Good luck
Jul 11, 2010 | Cooktops
Ignitors clicking
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
May 15, 2010 | Dacor Preference SGM365SS Gas Cooktop
Igniter doesn't spark on only one burner
There are three parts to the ignition system typically.
The ignitor that is either in the burner or outside the burner.
The spark ignitor switch that is located on the burner control. (( one for each control ))
The spark modual. the modual creates the hi-voltage spark.
If the burner that does not ignight with its control does not spark but does spark with one of the other controls then the spark ignitor control switch is bad.
You can test it with one of the other burner control knobs. (( just try a working burnder and when it clicks look at the bad burners ignitor and look for the spark.))
If the bad burner that wont ignight does not spark then either your modual is bas or the ignitor is shorting out.
If you see any little spark but it does not spark from point A to Point B like the other burners then your ignitor is shorting and should be replaced.
If your ignitor is ceramic and it is cracked, then it should be replaced.
Jan 13, 2010 | Miele KM360GSS 23 in. Portable Gas Cooktop
Spark ignitors on ge jgp636 either don't work or lght wrong burnr
Dec 19, 2009 | GE Profile JGP636 Gas Cooktop
Bad ignitor needs replacement
it may just need cleaning at where it sparks to the burner if it is sparking back down the electrode then it is cracked . Some igniters pull out others have a screw that holds them in.
Oct 23, 2017 | Jenn-Air JGC9430ADS Gas Cooktop
Ignitors are not working
Nov 17, 2008 | Jenn-Air 36 in. CCG2523 Gas Cooktop
Ignitors Continue to Spark
Turn the knob back towards off about 1/8 of a turn and you will take it off lite and it should fix it.
Aug 27, 2008 | Thermador 37 in. SGSX365 Gas Cooktop
Stove top [gas] JENNAIR
Try carefully cleaning around the ignitors. Also clean hole in burners. Clean the holes closest to ignitors. This can be caused by a crack in ignitor, this requires replacement.
Nov 05, 2007 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Jenn-Air JGC8536 Gas Cooktop Logo
356 people viewed this question
Top Jenn-Air Cooktops Experts
Marvin
Marvin
MARLON KELLER
Paul Carew
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
