2003 Chevrolet S-10 Logo
A
Anonymous Posted on Sep 23, 2011
2003 s-10 changed motor, now won't start. you can
Jonah Oneal
Level 3:
  • Chevrolet Master 14,092 Answers
  • Posted on Sep 23, 2011
Jonah Oneal
Chevrolet Master
Level 3:
Answers
14092
Questions
0
Helped
7236546
Points
44533
CODE P1637 - GENERATOR L TERMINAL CIRCUIT MALFUNCTION CONDITIONS. CODE P1638 - GENERATOR F TERMINAL CIRCUIT MALFUNCTION CONDITIONS. POSSIBLE CAUSES FAULTY GENERATOR WHICH IS ALTERNATOR.CHECK GENERATOR POWER FEED WIRES AND CHECK GENERATOR VOLTAGE REGULATOR WIRES FOR LOOSENESS AND DAMAGE. MAKE SURE BATTERY VOLTS ARE 12.6 VOLTS. IF BATTERY WEAK DUE BAD GENERATOR VECHICLE WONT START.
I have a 2004 Dodge Neon and I just replaced the battery and for some reason sometimes when I'm running a lot of errands when I turn it off it won't turn on again. It won't even make any noises...
Something is wrong in your start circuit. From battery to ignition switch, and ending at the starter solenoid. You would have to start checking for where power is lost between the switch and the starter. If you have power to the starter solenoid on the small wire at the starter (can check with a test light while someone holds the key in start), then the starter would need testing.
88 Mustang GT won't turn over unless I jump the starter relay.
Hi Kevin it sounds to me like your solenoid that is attached to your starter motor needs replacing had this with a ford cortina mk 5
1helpful
My 2008 silverado won't start battery is charged
No, it isn't an ignition issue.
Check power to the starter motor solenoid.
If this is getting power when cranking, then the issue is with the starter motor solenoid or starter motor. Replace.
2003 Dodge Neon won't start, try to jump start it
check for the starter motor but I suspect a flywheel gear worn. By removing the starter motor would be easier to check the flywheel gear.
1helpful
I have a 2000 Ford Taurus. My wife left the radio running with the ignition off for a short while. Now the car won't turn over, won't start, won't jump. There is one click when trying to s
The click you are hearing is most likely the start slenoid making contact, however you should short the large wires @ the solenoid to make certain the starter still doesn't run, if so try tapping the starter with a hammer to shift the comutator a litle and try to start. Even if it now starts the starter will continue to give you problems so the proper fix is change the starter
1999 Ford Escort ZX2 won't start
It's called the clutch start switch. Yes, it could be bad or needs adjustment.
Push the clutch in and the switch closes contact, so power flows from the ignition switch start position to the clutch switch and on to the starter motor-well, actually to the starter solenoid on the starter motor. If you have a voltmeter or test light, you can test the clutch switch . A red and white wire to it and a red wire from the switch to the starter solenoid. When this wire gets to the solenoid, it is a black wire with red stripe. It should have voltage when key is held in start position and the clutch pedal is depressed.
Starter motor car won't start
I am guessing that you already suspect the starter motor. If the battery is fully charged and the car won't crank over that could be the problem. You could try jumping across the starter solenoid first, if you can get to it and see if maybe it is just the solenoid. You could take the starter to a place like AutoZone and they can test it for you.
1966 mustang 289. won't start, jumped across solenoid, started. Replaced solenoid-starter wouldn't disengage, replaced starter, back to square 1, jumping across solenoid to start - whats my...
Ignition problem... No signal from ignition to solenoid...run a starter draw test to confirm starter is ok --- You can run your jump wires to a remote starter button or switch to get around it for now.
I hope this helps.
94 cadillac won't start, even with a jump. Battery is new and inside lights do come on, but vehicle won't start. Any advice? Thanks
Check the starter/solenoid - sounds like either one or both need replacing. If you can get the starter off - you can take it to an Auto Zone or an O'Reilly's to get it tested. I'm not sure of any tests for the solenoid (sometimes it's part of the starter) - some cars also have a starter relay switch. If that's the problems - it's usually cheap & easy to replace.
Car won't start. tried banging on starter celenoid, still won't start. Power comes on tho.
IF POWER GOING TO STARTER SOLENOID, EITHER STARTER SOLENOID FAULTY OR STARTER MOTOR BAD.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Chevrolet Expert? Answer questions, earn points and help others
