Http://www.beverage-air.com/Main.aspx?pid=49&tab=50
Go to this site and see if the Manual is for you unit.
SOURCE: Need to know what type of freon to use to recharge
There is a data plate on unit somewhere most likely 134A.
SOURCE: Beverage-Air 74 cu. ft. / 2095 liter Commercial
You might be able to. Turn the thermostat up, throw a thermometer into the box and play with it for a few days until your happy with it. But, be sure to keep the thermostat in it and load it slowly over a few days. You'll need to keep an eye on how it reacts when you start to load it up. It might see a load and turn back into a freezer. just load it slow and keep an eye on it. If you turn it up and is doesn't get above freezing, don't think you can load it up to bring the temperature up. It might work at first, but as it catches up, you'll find out you still have a freezer!!
SOURCE: need conec of electrical system heather elemt,
http://www.beverage-air.com/Main.aspx?pid=50&tab=51 you will find the pdf files for specs & manuals here.
