Air leaking from the pressure switch indicates that the in-tank check valve is leaking. Follow the air discharge hose from the compressor to the tank. The brass valve at the tank is the check valve. With air in the tank remove the inlet hose from the checkvalve and spray soapy water on valve to check for leaks. If leaking, remove the valve and check for debris under seat or replace. If the check valve is not leaking then pressue switch is leaking from within switch(spray soapy water below switch) . Good luck
