I have a panasonic kx-dt343, i can find the incoming call log but only calls that i've answered not ones i've missed. how do i check the missed calls? how do i set it up so the phone will flash if i have a missed call?
Re: I have a panasonic kx-dt343, i can find the incoming...
Normally, the ICD group is 601. So, press PROGRAM, pick a button, and dial 54601 STORE. The button becomes a log for all calls ringing into the 601 calling group.
Odd. What happens when you dial 601? Your ICD group may be 600 instead, but it's supposed to work :-)Odd. What happens when you dial 601? Your ICD group may be 600 instead, but it's supposed to work :-)
You can't post conmments that contain an email address.
Calls log auotmatically to phones that ring. If more than one phone rings the call will log on the phone that answers. If no phone answers, the phone connected to the lowest port number will log the call. The lowest port number is usually the lowest extension number, but not always depending on how the phone system installer numbered and connected the extensions. Also if a call is transferred to a phone it will log. The logged calls can be seen by navigating the LCD screen.
With the handset still on hook press the MENU button on the far right of the screen. Scroll down with the arrow key ( bottom right corner of phone ) until you see incomming or outgoing call log. Now press ENTER to view. PLEASE vote/rate this answer if it was helpfull. Thank you
A Panasonic TDx system has 2 types of call logs, one personal for the set, and one for the ICD group.
Pick a spare button, press PROG, the button, and dial 54 STORE.
If you had incoming: 00x on your display, that button will light and you can now press it to see who called. Your Navigator UP/DONW key will step you forward or backward through the log. The LEFT/RIGHT key will display the 4 lines of the display if you're not using a 7636 phone.
If you want to see incoming calls to a particular ICD group, pick another button, and dial 54 plus the ICD group number. For example, I used 100 as my ICD group (now 600 by default). I have 2 buttons, one logs my extension calls, one displays the system calls.
