Computers & Internet Logo
Posted on May 19, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Problem: emachines T6536 with xp 64 "no midi playback device". 1. Cannot get this to install. 2. Have oem disc labelled "Operating System Disc (Dual-Core). 3. This T6536 model has been reloaded many times without a fault. 4. Last reload, no audio with error 39. 5. Added "streamci.dll" then codec files. 6. Result! (no midi plyback device). 7. Is this a mother-board or software problem? 8. The operating system disc is not scratched and is kept in a climate controlled enviroment. 9. What is your guess?
GI Consulting
Level 2:
Scholar:
New Friend:
  • Expert 119 Answers
  • Posted on May 19, 2017
GI Consulting
Expert
Level 2:
Scholar:
New Friend:
Answers
119
Questions
0
Helped
25568
Points
405
Visit the eMachines website, put in your model number: T6536 and then choose Windows XP 32 bit, and download the sound driver:
http://www.emachines.com/ec/en/US/content/drivers.html
Even though you indicate that you have a 64 bit version of Windows XP, the 32 bit driver should work for the sound.
5 Related Answers
egadgetguy
Ken Williams
  • 263 Answers
  • Posted on Sep 03, 2008
SOURCE: Only getting EMachines/Windows XP Logo when boot up T3882
You have to press and hold F1 until it shows that it's loading BIOS. Then check the boot sequence. The CDROM sohuld be first.
Booting into safe mode is another story.
To get into the Windows 2000 / XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Anonymous
  • 126 Answers
  • Posted on Nov 23, 2008
SOURCE: No Audio
I have a friend with a systemax, same thing happened to him.
Go into the control panel, select sounds and audio devices, go over three tabs to the audio tab, make sure the sound default device is the onboard audio card. Should be all set.
Let me know how it works out.
Anonymous
  • 26 Answers
  • Posted on Mar 19, 2009
SOURCE: Need to reload windows xp on Emachines PC
Yes all you have to do is.........
Turn off the Computer
Turn back on and Press F11 repeatedly when the message "Press F11 to start recovery" is displayed.
The recovery will load and display a menu of options:
Full System Restore (with Backup): This options will move all Hard Disk contents to the "c:\My Backup" directory and install a new copy of Windows. This option preserves your existing data files, however all applications and settings will need to be reinstalled. This option requires 4GB of free Hard Disk space for the new OS.
Alway suggest backing up your data before you do any recovery
Anonymous
  • 79 Answers
  • Posted on May 31, 2009
SOURCE: Software Driver reuired
http://support.amd.com/us/gpudownload/windows/Legacy/Pages/integrated_mce-xp.aspx?type=2.7&product=2.7.5.3.3&lang=English
Anonymous
  • 11 Answers
  • Posted on Jul 02, 2009
SOURCE: computer shows no display
did you try installing newest drivers from intel/gigabyte website? what you described looks to me as a overheating problem. try running the game with case open. are you running on the integrated GMA graphics or PCI-E graphics card(like geforce, radeon)?
I tried to Reboot my pc with System Disc and it is asking for a second disc. I have 1 of 1 system disc. what is disc 2
It may be a content disc. One probably holds your operating system, the other holds your preinstall programs.
tip
Windows Installation Disc VS Windows Upgrade Disc -NOT THE SAME-
Having Trouble Booting To Your Windows Upgrade Disc?
...Upgrade discs aren't bootable discs. To repair a windows installation, you must use either a system repair disc or, better yet, a windows installation disc (genuine Retail/OEM discs are pretty much your only option to completely reinstall your windows operating system, unless you own a previous full installation disc of a previously released Windows version (such as XP or Vista), in which case you could install that windows operating system and then upgrade to a newer windows OS like windows 7. however if you ever need to reinstall windows 7, you would either need to reinstall the older windows OS, then upgrade to the newer one.
If that isn't clear, I'll sum it up....
Let's say you bought a computer, that computer had windows xp home edition. Maybe you wanted to upgrade from Windows XP/Windows Vista or Windows 7?
Well in order to switch from Windows XP/Vista to Windows 7, (or even from Windows 7 home premium- to windows7 Pro or Ultimate), then you must either:
A) Buy an upgrade disc and upgrade to the newer desired version.
B) Or, Buy a Retail Copy of the version you want to install. (keep in mind that a retail Windows 7 disc can be used to perform an upgrade rather than to competely wipe the hard disc and perform a clean install (delete partitions, reformat, and perform a new windows installation), if you so choose.
The bottom line is, you cannot Install a fresh clean copy of windows using an upgrade disc. OEM (Original Equipment Manufacturer) and Retail Windows Operation System Installation Setup Discs are "Bootable Discs". Windows Upgrade Discs are NOT bootable. (unless one where to "modify that particular disc, which is not legal).
on Jul 06, 2010 • Computers & Internet
What are the System reqirements for Nero Video Premium HD
Copied form this link
Nero Video Premium HD - System Requirements
Minimum system requirements for Nero Video Premium HD
  • Windows® XP SP3 (32-bit), Windows Vista® SP1 or later (32 and 64-bit), Windows® 7 Home Premium, Professional or Ultimate (32 and 64-bit)
  • 2 GHz AMD or Intel® processor, 512 MB RAM (1 GB RAM for Windows Vista® or Windows® 7)
  • For Blu-ray Disc Playback and HD Video Editing: Processor Intel® Core™ II Duo 2.2 GHz, AMD Athlon 64 X2 5200+ 2.6GHz or above, 2 GB RAM
  • 5 GB hard drive space for a typical installation of all components (including templates, content and temporary disk space)
  • DirectX® 9.0 compliant graphics card with 3D acceleration, 16-bit color, and a minimum of 128 MB video memory is required (32-bit, true color, 256 MB dedicated video RAM, and support for Shader Model 3.0 is recommended)
  • For Blu-ray Disc Playback: Graphics Card NVIDIA 8600 and above, ATI Radeon HD 3800 and above, Intel G45 (Windows Vista/Windows 7); Minimum 512 MB VRAM, HDCP compliant display for digital connection
  • DVD disc drive for installation and playback, Blu-ray Disc capable drive for BD playback
  • CD, DVD, or Blu-ray Disc recordable or rewritable drive for burning and video authoring
  • DirectX® 9.0c revision 30 (August 2006)
  • Windows Media® Player 9
  • Third party components such as Microsoft Windows® Installer 4.5, Microsoft .NET™ 3.5 SP1 and Microsoft Silverlight™ 3 are shipped with the product or automated download if not included in the package
  • For some services and the use of BD-LIVE features an Internet connection is required (DSL-1000 and higher recommended). Internet connection charges are the user's responsibility
  • For further requirements please check www.nero.com
Note:
  • On 64-bit operating systems, applications run in 32-bit emulation mode
  • Nero DiscCopy Gadget does not run on 64-bit operating system
  • The devices must be correctly installed and recognized by the operating system for the product to work properly
  • Installation of the latest WHQL certified device drivers is strongly recommended
Special / Minimum requirements for video editing and authoring
  • OHCI compliant FireWire® controller (IEEE® 1394) for DV or HDV™ capturing
  • TV tuner or video capture card for analog and digital video recording
  • Up to 50 GB hard drive space for disk images and temporary files
  • For support of NVIDIA CUDA™ technology a CUDA™ capable graphics card must be installed.
    For more information see http://www.nvidia.com/object/cuda_learn_products.html
Mi problema es con el ciberlink powercinema 5, cuando lo abro la tv se escucha pero no se ve y se queda pillado el ordenador, tengo windows xp sp3 pro.
It can be the TV Tuner Card.See this:
Operating System
  • Microsoft Windows 7, Vista and XP SP3* (Windows XP Service Pack 3 is required)
Processor (CPU)
  • Blu-ray Disc playback: Pentium 4 541 (3.2 GHz), Athlon 64 X2 3800+ or above
  • TrueTheater 3D playback: Pentium D 950 (3.0GHz), AMD Athlon 64 X2 3800+ or above
  • DVD playback: Pentium 4 (2.4 GHz), Athlon 64 2800+ (1.8 GHz) or above
Graphics Processor (GPU)
  • Blu-ray Disc playback: Intel G45, ATI Radeon HD 2400, NVIDIA Geforce 7600GT or above
  • TrueTheater 3D playback: Intel G45, ATI Radeon HD 2400, NVIDIA Geforce 8800GT or above
  • DVD playback: AGP or PCI Express graphic accelerator supporting DirectX 9.0 or above
    • Note: we strongly recommend that you update your graphics card driver to the latest version. 3D display devices are required for TrueTheater 3D playback.
Memory
  • Blu-ray Disc playback: 2 GB required for Vista and Windows 7; 1 GB required for Windows XP
  • DVD and TrueTheater 3D playback: 1 GB required for Vista and Windows 7; 512 MB required for Windows XP
Hard Disk Space
  • 300 MB for product installation
Display Device
  • DVD and Blu-ray Disc playback: HDCP compliant display for digital output. TV or computer monitor for analog output
  • TrueTheater 3D playback: 3D display and 3D glasses required. HDCP compliant display for digital output. TV or computer monitor for analog output
Disc Player
  • Blu-ray Disc playback: BD-ROM/BD-RE or Super Multi Blu combo disc drive
  • DVD and TrueTheater 3D playback: DVD-ROM, DVD+-R/RW, DVD-RAM or DVD Super Multi combo disc drive
Microphone
  • A microphone is required for recording voice-overs in Movie Remix mode
Internet Connection
  • Internet connection required for web services
2answers
How do you reload XP on a C2220 Fujitsu laptop when the partition is gone? Fujitsu doesn't provide an XP recovery disk, they only put XP on the partition. But my partition is gone.
If you have deleted that recovery partition then you need a Windows XP installation CD.
If you do not have this CD then contact Fujitsu for a copy of Windows XP installation CD, you may need to provide proof of ownership etc.
The Windows XP installation code should be on a Windows label on the bottom of your laptop, this is required when you start installing Windows.
You will also need to download the Notebook's device drivers from the Fujitsu WEB site to install on the notebook. You most likely need to download them from a different computer and then copy and install them onto the notebook.
1helpful
2answers
I lost the operating disc that came with the my emachines T4010 how to do restore
Use a regular Windows install disk and find from here
http://www.emachines.com/support/drivers.html
and install the drivers yourself.
4150 emachine problems reading operating system
check if the cd is the number 1 boot device
1helpful
4answers
Hey I have a really bad problem i have trojans and spyware that I can't get off I can't even download any thing I can use Internet Explore but when I go to a web site to download something It will not let...
Reinstall the Operating System. And first thing you download should be AVG Antivirus from www.download.com. It is a free prog and is excellent. After that you can install whatever you need or want.
Bhim
Sorry, no, you cannot 'convert' the 64 bit system to the 32 bit one. You
have a few options. All of them are coloured by the fact that the OEM
license gives you the right to use just the version you originally
received.
1. Remove the 64 bit version and install the 32 bit. To do this, you
might be able to arrange with the original source to get the 32 bit OEM
version. Alternate, purchase the 32 bit license of the retail version.
If the 64 bit version runs correctly (all the devices/peripherals work
correctly) and the issue is program compatibility:
2. Install the 32 bit in a dual boot arrangement. A Google search will
yield links to various sites with the instructions for doing that. Do
note that you should get the method for installing the 32 bit after the
64 bit
system.
Since you have an OEM version, your first point of contact would be
whoever you got it.
2answers
System Restore (Destructive) GM5084 Gateway Media Center w/ XP
what operating system disk do you have? xp, xp pro, vista?
Grand Canyon Tech
Grand Canyon Tech
