If
it\'s within the magnetron portion of the warranty (usually 5-9 years)
but out of the original full warranty (usually 1 year), then your
manufacturer will cover the part cost, but not the cost to visit you or
the labor charge to do the work.
Since the turntable and light are working, the most common causes of a failure to heat are:
- loose or corroded connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron
- shorted high voltage diode
There should also be a "mini-manual" hidden inside the unit behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting & testing.
We\'re happy to help you and we\'d appreciate your
thoughtful rating of our answer.
SOURCE: GE spacemaker microwave does not heat food; fine otherwise.
Most likely the hi volt energy components. Usually the hi volt diode or hi volt capacitor. There is hi energy stores here so be careful or do not attempt it. A person skilled in electronics, tv repair, or microwaves can handle it . It is usually worth repairing. The other parts that could be the problem are the magnatron or the hi volt transformer; if so, you might think twice before repair (the price will be higher).Goodluck, Macgivor
Testimonial: "Thanks for the quick response ... I don't want to mess around with something only a professional should be touching. Thanks for the advice ..."
SOURCE: GE PRofile Spacemaker XL Microwave Oven Model# JVM1460 950 watts
Sounds like the problem is in the high voltage. Most common would be magnatron, capacitor and diode. For safety reasons this should be checked by a professional. Look in your owners manual because some high voltage parts have a longer warranty than 1 yr.
SOURCE: GE Spacemaker XL 1400 Microwave
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
SOURCE: Microwave not heating food
It's most likely the Magnetron. The are not very easy to install and quite expensive. Older models magnetrons cost about 80 bucks from GE. It's probably not something you would want to try and repair yourself. Call a GE service person.
