Hi 312pdl ,
Thanks for your question at Fixya,
Please find the solution to your problem as follows :-
The spring that you have described , is held by a small gasket which is not easily visible.
This spring is present to keep the coffee in the filter system so you can put in there, you must have got an idea as to where you have to put it.
Try to find the appropriate slot and then put it there.
Hope this helps ...:) In case you have any queries , feel free to contact me.
Hello.
What you will have to is to get another part( screw or spring ) from any of the authorise store that repair coffee maker or sale home appliaence arond your local area in other to be able to make use of the maker again.
Thanks.
I have the srew and spring and cover just need to know how it goes back in.
Went to clean my coffee maker and wanted to clean it through and removed the screw under the slide out draw on the left. When I did a spring popped out and I don't know which way it goes back. Has something to do with the button on the side. Please advise.
