Hi F21 error in your Bosch washer relates to a motor or a
control board fault. This can be reset and to reset it turn the appliance knob
to the off or reset position (12 o'clock), turn the knob to the 6 o'clock and
then press and hold the spin button, then while holding that button turn the
knob to 7 o'clock position, continue holding spin button for 15 seconds and
then turn the knob to off. After a minute turn it back on, if the error code is
still there then it means that the motor or brushes in the motor should be
replaced, though it is always better to replace the motor assembly completely. Hope
this helps...please post back for further assistance. Daniel
Yes right
Unplug the washer and then try to reset it again (hope you are pressing right buttons to reset it), if the issue remains then yes it can be due to a bad motor or bad connections which should be checked.
Do the reset with the door open.
SOURCE: i have a bosch maxx
From the user manual in English:
F:21 - Motor fault. Call customer service!
SOURCE: How to reset the error codes (F21) on Bosch Maxx
See this url
http://experts-univers.com/mon-lave-linge-bosch-maxx-7-ne-fonctionne-plus.html
Hi
Daniel
F21 relates to a motor or control board fault.
However, it is also caused by spikes in the mains and can be spurious.
To reset it.
Turn the appliance knob to the off or reset position, 12 o'clock.
Turn the knob to the 6 o'clock position.
Press and hold the spin button.
While holding it, turn the knob to the 7 o'clock position.
Continue holding the spin button for about 5 seconds.
Release the button.
Turn the knob to off.
When your turn it back on it should have cleared the error code
Hi Daniel
The spin butten - is it the same as ON botton...the start the machine ?
The F 21 error is still there - yesterday the power from the powercenter brake down in the houl area - is there any conektion there you yhink ?
