When i turn it on it says the system software cannot be run correctly. press the PS button to try to restart the system. if the system cannot be resarted, you must reinstall the system software. i press the button it comes back on and the same screen pops up.
You may want to try using a hard drive partitioning software (Paragon) to install a FAT32 partition on the HDD and insert it back into your system. I have read that some large capacity new drives are not recognized by the PS3.
Yes very common problem with this harddrive..you must upgrade to a 60gbSATA
- Hold down MODE + RESET for few seconds
- Press the Power button to turn on the device
Hard Reset
(This will erase all of your data inside the device)
- Hold down MODE + RESET + POWER for few seconds
Firmware Downgrade/Upgrade (2.9 > 2.8 > 2.9)
(This will erase all your data inside the device)
Software Downgrade/Upgrade
- Connect your Garmin Forerunner 305 to the computer
- Press the UP arrow button and hold while doing all the other steps below
- Press MODE + RESET for a moment (the computer will recognize the device)
- Dowload the Firmware from Garmin's website.
- Downgrade Firmware from 2.90 to 2.80. (You are still holding on that UP arrow button!)
- When the update is finished the Forerunner 305 should power on running the Firmware 2.80.
- Let go of the UP arrow button, disconnect the device from USB, connect it again and the computer should recognize it normally
- Update the Firmware to the current version.
The same here, only with a 400gb HD...
Ditto
