E-Machines W6409 (7234) PC Desktop Logo
Posted on Apr 16, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I'm trying to install the original splash/bios screen for an emachines w6409. i downgraded windows vista back to windows xp with the disk that came with the computer. i was missing drivers so i looked around online. i found a forum that directed me to ALL DRIVERS for my computer. ever since i did that it says i now have 30 days to activate windows. i enter the lisecense key from the sticker on my tower. no luck. call microsoft with an installation id. no luck either. so basiclly i just wanna get it back to 100% factory settings. how do i get the original bios with the big white e when i turn it on.
Larry Ng
Level 3:
Top Expert:
  • E-Machines Master 14,591 Answers
  • Posted on May 16, 2022
Larry Ng
E-Machines Master
Level 3:
Top Expert:
Answers
14591
Questions
0
Helped
3277553
Points
66570
XP ran form 2001 to 2014 and ended then 100$ DEad as in
StaR TREK "HE'S DEAD JIM , DEAD"
XP is A virus magnet (from H3LL")_
99% of all non OEM drivers found via google are virus infected.
the coin cell battery is dead, if is can never be ignored.
the tower sticker is OEM only and will not work with retail disks
only with OEM emachine install disks
and same goes with the reverse of that, retail coa on OEM disk fails
and now MS ended it all, DOA , EOL, kaput.
well, bios never ever ever works with the battery dead it will never happen, PC 101 class day 1 facts as are bad HDD..
what can work are hacked XP install disks that are now neutered.
others hack out the reg features. not asking for COA again.
but all those are infected too
why not just get a real PC, 2010 and newer and load w10=64b
like a fine DELL 3020MT or wow 9020 MT pure love and very cheap.
expelled from silly business's as knee jerk upgrade and our GAIN.
i5 gen 4 up.
3 Related Answers
yashan.co.in
  • 202 Answers
  • Posted on Jan 25, 2009
SOURCE: Restore back to factory setting
take any of vista disk(any copy)
boot with cd in repair option get restore click.
Anonymous
  • 814 Answers
  • Posted on May 16, 2009
SOURCE: Emachine locks on windows splash screen
Try flashing the Bios, if this does not work you may have a processor problem or a problem with the operations of the northbridge or southbridge not functioning correctly causing the freeze problem.The only repair for this type of problem is to replace the motherboard. If the computer is over three or four years old this may be the situation. You should check the condition of all the processors before giving up on the board.Try removing the heatsinks and reapplying the thermal paste. Make sure to clean all dust and debris form the processors. Make sure all the heatsinks are making good contact with their processors. Be sure to clean all dust and debris form the inside of the case and under the motherboard. Check all the screws and standoffs, Just or make sure you are not having shorting problems between the motherboard and case. Hope this helps you with your problem.
Anonymous
  • 66 Answers
  • Posted on Jul 29, 2009
SOURCE: Emachines W6409 that restarts over and over
Before you do that make sure that there is nothing plugged into your computer like any third party device.
Well try safe mode with command prompt if yes than you can access system restore
Steps to perform system restore
  1. Restart your computer, and then press and hold F8 during the initial startup to start your computer in safe mode with a Command prompt.
  2. Use the arrow keys to select the Safe mode with a Command prompt option.
  3. If you are prompted to select an operating system, use the arrow keys to select the appropriate operating system for your computer, and then press ENTER.
  4. Log on as an administrator or with an account that has administrator credentials.
  5. At the command prompt, type %systemroot%\system32\restore\rstrui.exe, and then press ENTER.
  6. Follow the instructions that appear on the screen to restore your computer to a functional state.
If that doesn't work than try repair install, you need to have OS disc for this For any clarification, let me know.
Upgrading windows vista to windows xp in presario 115DX
You cannot 'upgrade' Windows Vista to Windows XP - that is technically a 'downgrade' and would need you to save all your user data on Vista then format you Windows drive then do a clean install of Windows XP.
If you try to install XP over the top of Vista you will have lots of problems because of the difference in architecture and boot manager changes.
The only alternative would be to set up a dual-boot installation where you install XP alongside Vista but would be best done on either a separate disk partition or on a second disk. Normally such a dual-boot configuration would start with having XP installed then adding Vista as the second operating system.
Can't install xp in compaq laptop
you mean you need to downgrade your computer from Windows Vista to XP?
if so is the case, you need to go to the BIOS in the Boot menu, select IDE from ACPI.
put the boot option to boot from CD first or disable Boot from hard disk.
then you will be able to downgrade your computer from Vista to XP.
2answers
How to downgrade from windows 7 to xp on emachine laptop
If it is a new emachine, then it proberly will not let you. There is a problem with drivers. certain pieces of the hardware might no have any drivers that are supported by XP.. The best thing you can do is check the emachine website to see if any drivers XP. If so then follow this basic guide to format and re-install XP on your PC.
http://simontodd.com/2010/02/how-to-format-a-pc-and-reinstall-windows/
Thanks
2helpful
2answers
I have purchased an hp550 computer with the Vista operating system. i wish to downgrade to the win XP operating system. how is this done ?
Greetings.
There is no direct path to downgrade Vista to XP. You can’t simply insert the XP installation CD media into the CD-ROM drive and hope to ‘upgrade’ and replace the Vista with Windows XP usual install routine because Vista won’t allow it to be overwritten. XP will treat Vista as ’superior’ operating system and refuse to install over it. There’re actually few options available instead of completely uninstall Vista as listed below. But if you decide to downgrade from Vista to install XP, there is also a simple guideline that you can observe to ensure that the migration goes smoothly.
Option 1 – Dual Boot:
It’s by far the easier and best method to run XP instead of Vista if you have another partition or hard disk. Simply boot up any XP setup media and install XP into different partition or hard drive than the Vista installation. Once completed, you can choose to boot up either XP or Vista, and has the best of both world.
Option 2 – Virtual Machine:
Install VMware Server or Virtual PC 2007 (both free) or any other virtualization software, and then install Windows XP into the virtual machine
environment. You will get XP which runs inside Vista, with minor compromise on speed, performance and have to go through Vista first on every bootup.
Option 3 – Format the Hard Drive, Wipe Off Vista and Install XP:
For those who totally fed up with Vista and just want XP, or prefer a clean installation of OS has only this option to rely on. To downgrade to XP from Vista, you have to basically delete the whole hard disk that installed with Vista, and start anew with XP. Here’s a simple guide and procedures that you can try to follow to switch to XP. However, each system configuration is different, so you may have to adapt the steps to suit your own need.
1. Download all drivers for your system for Windows XP from the manufacturer’s website(in case if you don't have the CD/DVD installers). Copy the drivers files to a USB flash driver or external hard drive or burn them to CD/DVD.
2. Find a Windows XP installation CD (should be pretty easy to find or else you can search in torrent sites such as Demonoid to download via BT network such as uTorrent and BitComet or search and download via ED2K network client such as eMule. You can also use Volume Licensing (VL) CD, retail (FPP) disc, or system builder hologram CD provided by Microsoft.
3. You will also need a XP product key even if you legally can downgrade from Vista Ultimate or Business edition. The Vista serial number won’t works with XP. (try to search for XP product key on web).
4. Backup to USB flash disk, external portable hard disk or CD/DVD every data files and any other things such as documents, downloads, pictures, movies, programs and etc that you need and want to keep. You can also create a second partition with disk management utilities such as Acronis Director or Partition Magic, and then move the data files to the new partition.
5. Ensure that also you have CD or DVD setup media for the software applications that you want to install and use after wiping off your system from Vista.
6. If your OEM doesn’t provide you with recovery CD/DVD discs and Windows setup media discs (it’s because they’re stored in the hard disk in hidden location), you may want to burn a copy of recovery CD to CD/DVD first before you proceed, just in case the hidden partition is lost and you want to recover your computer to original state. (How-to Guide: IBM/Lenovo ThinkPad recovery CD)
7. If the system has SATA (Serial ATA) hard drive, locate the driver for SATA controller and put it in USB flash drive, diskette or CD first. If you have PATA (normal IDE) hard disk, simply go to BIOS CMOS to disable SATA or Native SATA mode if you don’t want to install XP on SATA hard drive. Else, you can also create an XP install disc with the SATA drivers integrated by using tool such as nLite.
8. In the BIOS, also set the CD or DVD optical drive as the first boot device in the boot sequence.
9. Put in the Windows XP installation CD into CDROM drive and boot up the computer by using the CD. You probably need to press a key when prompted with “Press Any Key to Boot from CD…”.
10. If you’re using SATA hard disk with driver on external media (not integrated into XP setup disk), remember to press F6 when you see the message at the status base: “Press F6 if you need to install a third party SCSI or RAID driver…” during the very initial stage of setup to load the SATA driver so that the SATA hard disk can be recognized.
11. Run through the setup wizard at per normal. However, when prompting for where to install Windows Vista, delete (by pressing D and then confirmation), create and format the Vista disk drive or partition (if you have multiple partition). And then choose to install on that just formatted partition or hard drive.
IMPORTANT: If you choose the wrong hard disk or partition with data to delete, you will lose your essential data.
Note: If the setup does not allow you to delete or format the Vista partition or drive, you will need to find a third party software that can recognize and read NTFS filesystem to clear the drive or partition first.
12. Enter any product key for XP. Vista product key will not work.
13. If you own a legitimate Windows Vista edition that allows for downgrade (See Vista downgrade rights), call Microsoft after performing the clean install of Windows XP Pro to activate the XP installation. Notify Microsoft that you’re downgrading from Vista and require to activate XP Professional or other version allowed newly installed. You won’t get a new Windows XP product key though. You will have to read out the long Installation ID plus your original Vista serial key, and Microsoft will provide an activation ID that will make the XP usable.
14. Install the drivers for your system devices.
15. Reinstall any software programs that you want to use.
16. Move back the data files and documents.
Thanks
Want the best bios for Asus M2N68-LA motherboard to run on win xp
You don't need to change the bios to do that, you already have the best one.
1helpful
Downgrading vista to xp
Now you need to find a Windows XP install disk that can match the licence number printed on the sticker at the back of the laptop and reinstall XP using your serial key.
You will have to download and install also the XP drivers, you find them on manufacturer website.
See links below on reinstalling XP on a Vista system:
FAQ: Giving up on Vista? Here's how to downgrade to XP
How to downgrade from Vista to XP News
How to Downgrade from Vista to XP
Downgrade Vista to XP pro
downgrading from vista to xp
2answers
Problems with used Emachine W3623 Windows vista Home basic
Simply put, No.
Chances are the performance of vista on an eMachine is an ugly sight anyway. My advise would be to downgrade to XP or try a good solid Linux distribution like Ubuntu. It will preform faster and be more stable that it ever was with Vista. Don't get me wrong I am not a total vista hater but it is a hog.
Best of Luck
2answers
DOWNGRADING
Boot from cd and delete partion where vista is installed after that play set up .
Top E-Machines Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
