Question about Soyo Crystal DYLT032B 32 in. LCD Television
Power is on in standby, but takes several times pushing the power button for the power or tv to actually come on
    Scholar:
  • 159 Answers
Very bad for the TV, don't do this!
Got the remote control? Switch on or off (full operation) from Standby with it and just use the main manual switch on the TV for, say, morning ON for the day and evening OFF for the night.
Posted on Sep 21, 2011
Anonymous
SOURCE:
Hi? My Sony Projection T.V model KP-FX432M91 is taking time to power on and once it has powered on it work fine.what might be the problem?
Power button may need to be replaced. Try turning on via remote.
Some TVs need to warm up before coming on. Hitting the power button several times may in all actuality be Turing it off and on.
Sep 20, 2016 | Sony Kp-Fx432M91 43" Projection Wega...
Tv is stuck on standby. The standby light (red) is steady and when I press the STANDBY button, nothing happens. no response or flashing light.
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
May 11, 2015 | Televison & Video
Sony Trinitron Wega Standby blinks & the TV won't turn on
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 12, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Screeen
If it's a big tv it can just take a little while to power up, I've found that pushing channel up button switches on tv quicker but I've no idea why.
Unless you want to save power you should only be switching tv to standby, there will still be a light on the tv somewhere, blue or red it varies. TV's turn on much faster from standby than completely off.
Jul 23, 2009 | Samsung HLS4666WX 46" HDTV
No response to any button on remote or tv except power button
Press the 'Favorite' button on the remote. You may have accidentally pressed it. It locks the channel. Pressing again unlocks.
Apr 22, 2009 | iLO 3200 32 in. LCD Television
Sony FD Trinitron WEGA KV-24FS100 24" TV On/Off problems
I have spent about 4 hours tonight researching several tech sites and the Sony service manual for the same problem with my Sony KV-32HS510 unit. I was able to download the manual from a website http://www.eserviceinfo.com/downloadsm/31649/Sony_KV-32HS510.html and a TV Repair training lecture paper at http://www.repairfaq.org/sam/tvfaq.htm#tvhvp .
These TV sets have a safety feature where it will shut back down if a high voltage is indicated. Unfortunately, the electronics for these safety features are not very reliable and give false indication. Letting the unit sit off lets the capacitors leak voltage as well as cool off. These two factor help with the unit not falsely indicating a high voltage condition.
The D Board seems to be the most common failure component, but a 6 times flash could be an overcurrent/voltage failure from the A, B, or M boards. A 7 times flash is a Horizontal Deflection Stopped error with no additional information given in the manual for a fix. Again, in most blogs, the D Board seemed to the source of the failures.
A refurbished D Board part no. A1300319A can be bought for around $200 with a new board at $550 per the www.partstore.com site. Then add $100-$200 for an actual TV service technician and you have a repair bill approaching the costs for a new flatscreen TV.
Some tech types posted that they have actually repaired their boards by replacing individual components for around $40. You may find a service shop that can do the same component level repair at the $100-$150 level cost. It turns out that the closest authorized Sony repair shop is 2-1/2 hours away from us. Good luck finding someone close by.
We were able to get our TV to come back on after dozens of attempts and plan to leave it on until it dies all together. I may attempt my own D Board replacement when the time comes.
Dec 14, 2008 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
'standby' mode and akb error number
AKB 66 in self diagnostic test means...TV goes to standby (shut-off) for AKB problem 66 times. AKB is White-Balance signal and it is not proper or maintained in your TV. So error signal produced and TV goes to shut-down state.
Regardnig Standby button, its available on remote only. If you push TV Power switch, TV will switch ON, push it again to OFF TV. Power Button on remote set TV in standby status and you dont need to push power button of TV itself.
Aug 14, 2008 | Sony KP-53HS10 TV
Sony Triniton Wega Model KV 32HS510. After pushing the power button,the tv starts to power up, then the standby light blinks 7 times then pauses before blinking 7 times again. It continues to do this,...
This is usually an indication of a failure in the scan amplifier sections. When the scan amplifiers or high voltage sections fail, the main power supply will usually also require servicing.
It is very common that the fly-back and high voltage multiplier and also the horizontal output stage fails in these sets. Along with it, the power supply will usually require to be serviced. On rare occasions, the vertical deflection amp fails.
Jerry G.
Jul 08, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Soyo Crystal DYLT032B 32 in. LCD Television Logo
264 people viewed this question
Top Soyo Televison & Video Experts
Marvin
Marvin
Raj Patel
Are you a Soyo Televison and Video Expert? Answer questions, earn points and help others
