HP Business Inkjet 1000 Printer Logo
Anonymous Posted on Sep 21, 2011
Purchased new HP cartridges, installed them. Cleaned the print heads and the contacts and ran all cleaning and calibration progams. Nothing seems to help!
Vinaya Kumar Kuchipudi
Level 3:
  • HP Master 1,124 Answers
  • Posted on Sep 21, 2011
HP Master
Level 3:
Answers
1124
Questions
Helped
451132
Points
2591
Catrtridges are new but what about print heads?..replace print heads then try.. But check light patern print heads/catridge faulty.. click the link for light patern.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00001211
Epson Sx415 New Cartridge,empty already?!?!
1. New original ink tank will dried for several times of head cleaning procedure.
. ....ran a nozzle check and cleaned print heads because it wasn't printing any ink on the paper.... ???
Nothing at all? If yes, problem is in the printer main board. Lost electricity to the head.
I put new print cartridges in my 960c printer. They are hp 78 for color and 45 for black and white. my orange ink light will not stop blinking. It is not printing
I have an HP DeskJet 1220C that has been working fine for two years now. All of a sudden it can only print in pink and black. It is driving me crazy. I have tried the following without any success:
1. Replaced the cartridges twice
2. Aligned and cleaned the cartridge from the
computer
3. Soaked the cartridge head in hot water,
and made sure that all three colors will bleed
out of the head
4. Cleaned the cartridge contacts with an eraser
5. Cleaned the cartridge contacts on the printer
with a brush
Is there a cure, or is it time for a new printer?
I have an HP 2140 fax purchased one year ago. I have never replaced the catridge and have used the fax about once a month. Today I am trying to copy and it won't print. I cleaned the nozzle and still...
New cartridge wouldnt print but sounded like it was printing. You can check ink levels clean or align cartridge by pushing menu then tools. I cleaned contact points w qtip and alcohol. What seemed to work is putting alcohol on cartridge where ink is released and putting back into machine wet did this three times first time little dots of ink then a faint print and now it is printing must have been dried ink further then I could access.
2helpful
Hp officejet v40. new cartridge but missing blue when printing
Sounds like your cyan print head is clogged. You can try to get it flowing yourself by rubbing the print head with a wet paper towel. If you press the print head on a dry paper towel you should see three distinct lines of color. If you still don't see the cyan, try letting the print head rest on the wet paper towel on a surface that ink can be cleaned up from or one you don't care about staining. If the cyan still won't flow, you should go back to where you purchased it and return it for a new one.
My Microboards PF2 does not print color properly.
The next to last cartridge I installed did not print properly. It seemed like all the colors were not there so I weighed it on a postage scale and it weighed less than another new one I had. I called Microboards. They said to send it to them and they replaced it. It may not be that, but weighing it should give some indication if it is.
New tri-color ink cartridge prints only red
Are the Jets clean and unobstructed? Depending on printer model, have you cleaned your print heads? Consider also it may be a defective cartridge.
HP k80 will not print yellow
spounds like a defective print head bud. these do wear out and most of the time it will cost as much as a new unit.. Good Luck
k24674
Grand Canyon Tech
Grand Canyon Tech
