SOURCE: No flow to top spray arm
the tube feeding the top spray arm may be clogged. The top srpay arm seal may be defective as well.
SOURCE: aeg 60800 dishwasher showing c2 on panel,water
from other forum
Not pumping or pumping too slow. Check for
blockages in pipework, filter and pump. If all clear, replace pump.
Curing the fault on these machines doesn't always get rid of the error
code though. Some faults are locked in.
If you find this, post back and I'll try to help.
SOURCE: my dishwasher doesn't work. It won't clean the
It can be your timer, motor, or water value. I need more detail information.
SOURCE: The bottom of the dishwasher has an inch of water
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
SOURCE: Hi we have a Kenmore
My kenmore built in dishwasher will not drain. I recently cleaned it out around the drain due to water deposit build up. How do I check to see if there is a clog somewhere without pulling out the dishwasher.
