If
the machine receives a fax under one of the following conditions, the
machine will not be able to print the received fax and will
automatically store it in its memory.Ink has run out while receiving a fax.Paper has run out while receiving a fax.
1. Make sure that the plain paper is loaded in the Rear Tray.
2. Display the Memory reference screen.
(1) Press the FAX button, and press the Menu button.
(2) Use the (-) or (+) button to select Memory reference, and press the OK button.
3. Print all the received documents in the memory.
(1) Usemx 320 fax showed me - left.gifg src="/uploads/images/left.gif" alt="left.gif"mx 320 fax showed me - right.gif_mi" />(-) or (+) button to select mx 320 fax showed me - printallrxdocs.gif/b>.
mx 320 fax showed me - left.gif (2) Press the OK button.
mx 320 fax showed me - right.gif) Use the (-) or (+) button to select Yes, and press the OK button.mx 320 fax showed me - questprintall.gif The machine starts printing documents in the memory onmx 320 fax showed me - left.gif.
(4) Use the (-) or (+) button to select Yes
To keep the document in the memory, select No.
(5) Press the OK button.
* Click the "Menu" button.
* Press the arrow buttons to scroll through the options on the screen. Select
"MEMORY REFERENCE" and click "Start/Copy."
* Use the arrow buttons to choose "DEL. PRINTED RX" then click "Start" again.
Press "*" to select the "Yes" option from the screen. This will delete all documents from the fax machine's memory.
* Click "Stop" to finish.
