Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
Posted on Sep 21, 2011
I am trying to change ink cartridges on my epson stylus sx215 printer, but every button I press (including Index Sheet and Scan together) turns the machine off and then restarts. The machine will not print black print.
Anonymous
Level 1:
New Friend:
  • Contributor 75 Answers
  • Posted on Oct 01, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
75
Questions
0
Helped
22135
Points
83
There might be something wrong with the printer already, can you not change the ink by opening the front cover? cli-8c
2helpful
How do I change the ink cartridges on an EPSON STYLUS Sx215
Hi joanmcd2, Just go to control panel and go to (printers for xp)/(device and printers win 7) open the properties of the driver and goto Maintenance tab and then click the EPSON Status Monitor button, you will see the ink levels and there will be an option to replace the ink.
for details pls dwonload the Sx215 manual on this link
1helpful
Cannot change ink cartridge on epson stylus sx215. Need advice in plain english - some of the solutions already offered I cannot understand!!
press the index sheet button and the scan button at the same time, you then get setup menu. use" >" to select "change ink cartridge". the ink cartridge will move to the opening position. lift the grey plastic clip at the back, and it will open towards you. then they just pull out
1helpful
I have lost my handbook for my epson stylus sx215 and dont know how to change ink cartridges can anybody help
press the index sheet button and the scan button at the same time, you then get setup menu. use" >" to select "change ink cartidge". the ink cartidge will move to the opening position. lift the grey plastic clip at the back, and it will open towards you. then they just pull out
1helpful
How do I change the ink cartridge on an epson sx215
Here's how you change the ink cartridge:
1. press the index sheet button and the scan button at the same time,
2. You then get setup menu. use" >" to select "change ink cartidge".
3. The ink cartidge will move to the opening position. 4. Lift the grey plastic clip at the back, and it
5. Then you can just pull it out.
Hope this helps
Good Luck!
Thank you for choosing Fixya!
1helpful
How do you remove the ink cartridge on an epson sx215 please
19helpful
How do i change the ink cartridges on my epson stylus sx215
press: INDEX SHEET and SCAN both at the same time, use two fingers if possible.
Your epson monitor Screen should show: NOZZLE CHECK and below that a left and right arrow with 1/6 between them. using the right hand arrow key just below the monitor, scroll through to item 4. then press the green start key to get the carriage ink holder to move into change position.proceed .
Changing Ink Cartridge
Easy solution:
Press The index sheet button and the scan button at the same time.
In the printers window 'set up' will appear. using the left right arrows proceed to 'Ink cartridge replacement'.
Press 'start'. The ink cartridge holder will align itself in the middle of the space where it is easy to remove the cartridges.
I am disgusted with Epson making this so diificult to figure out. Once you know..then you know. but no amount of guesswork would have come up with the solution
Please rate!! Thanks, Prem
26helpful
7answers
Epson sx 200 printer cannot change ink cartridge
Ive just pressed the 'stop' button on mine and it moved the cartridge to show which ink needed replacing and then when pressed again it moved to the replacement gap
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
