There could be several issues with your compressor. Oilless compessors have a silicone vinyl piston ring that wears over time allowing compression to leak past thru cylinder. This condition will cause the tank to never reach enough pressure to shut off. Your pressure is very low however indicating other problems including leaking reedvalves in the head which would cause the discharge air to be very hot and faulty pressure regulator on the manafold giving you 0 pressure. Easy tests. Remove housing and examine the cylinder /piston by manualy turning the motor till piston is at top of stroke against head. Examine the condition of the cylinder close to top. If it looks scratched, then piston ring and cylinder should be replaced (cylinder kit n036517). If cylinder looks good, look for leaking discharge hose or very hot air being discharged. If very hot, suspect reed valves (reed valve plate n017592sv). To test the regulator on the manafold, fill the tank with air using another compressor thru the quick connect or remove a fitting and connect airline. The regulator should read same pressure as the other compressor. If no reading, the regulator is faulty. Take the regulator apart and clean/ lube components or replace with new (manifold regulator a18351). If when you take the cover off you find that the belt is slipping, also change the check valve at the tank. Faulty checkvalve will cause the belt to slip. Good luck with your repair.
It sounds like the main check valve is stuck closed. This valve is USUALLY right where the pipe from the pump enters the tank. Usually these valves stick open but yours sounds like it is stuck closed. The pump then pumps into a tiny length of pipe so it can't build pressure and will labor. Remove the pipe fitting from the pump into the tank and you should find the valve.
The proposed solution was not correct. We found the problem was in the pump not being able to reach sufficient pressure. Repaired pump.
