Expert
- Posted on Sep 21, 2011
Re: The microwave does't make any noise ,,,but the count...
HELLO.
The likely thing to be is that the microwave fan is faulty.the solution is to replace the fan.
Needed instrument:Phillips-head screwdriver.
Instructions on how to replace the fan is detailed given below.
1. Unplug the microwave from the wall outlet to prevent an electrical shock while
- working on the microwave oven.
- 2 .Remove
the screws holding the fan shroud to the top of the microwave oven.
Using a Phillips-head screwdriver, turn the screws counterclockwise to
back them out of the panel. Set the screws in a safe place so they will
be available for installing the new fan.
- 3.Slide
the fan shroud--also referred to as a damper plate--forward, toward the
front of the microwave, to remove it. Set the shroud to the side.
- 4. Lift the fan assembly out of the microwave. An electrical cable and plug is accessible once the fan assembly is out of the way.
- 5. Unplug the electrical connector from the fan and fully remove the fan assembly.
- 6. Set
the new fan assembly close to the top of the microwave to facilitate
plugging the new fan into the microwave's connector. Plug in the fan
assembly.
- 7. Position the new fan in the same orientation as the old fan's before its removal. Lower the fan assembly into position.
- 8. Slide the fan shroud in place and install the screws to secure the shroud.
- 9. Tighten the screws with the Phillips-head screwdriver by turning the clockwise.
- 10. Plug the microwave oven into the wall outlet and test the new fan installation.
Thanks
