Aastra Telecom Aastra 9417 CW Corded Phone Logo
Posted on Feb 26, 2018
The message indicator light doesnot reconize the beep sequence that Rogers gives. When you pick up the phone you receive a beep tone indicating a message but the flashing indicator light does not work. I have cleared the messages I have powered down the phone nothing seems to help.
1helpful
A few of our rooms has the voicemail light blinking. There is not a voicemail waiting and can not be cleared from the front desk or from the room.
Message Waiting Indicator Your phone's message waiting indicator is either a light or special tone that alerts you when you have voice mail.
Occasionally, the message waiting indicator may be out of sync with your mailbox. In that case, the indicator light or tone is ON but there are no messages waiting, or the indicator light or tone is OFF when there are new messages waiting.
To get the message indicator back in sync
  1. Save or delete all new messages
  2. Hang up.
  3. If the message indicator does not go out or stop within a few minutes, there may be a problem, and you should contact Verizon.
  4. If the message indicator does go out or stop, call your own number and leave a message
  5. Hang up and wait
  6. If the indicator light or tone does not come on within a few minutes, there may be a problem, and you should contact the vender.
Need to turn the voicemail indicator back on & get rid of beeping dial tone.
You apparently have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
2helpful
I have 2 problems. 1. The orange message light will not stop flashing no matter what I do. 2. Some how the system was switched from touch tone to dial tone. I can't seem to that switched either.
Resetting the voice message waiting indicator
When you receive a new voice mail message, the new message LED on the top of the handset flashes. In the event your message waiting light gets out of sync with your phone company's
voice messaging system, you can manually reset it back to the "No messages waiting" state.
1. Press and hold FiND on the base for five seconds.
Note: The handsets connected to the base will start to beep, however, keep pressing for five seconds.
2. A beep sounds and the message alert tone is reset.
Changing the dial mode
Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most base networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you will need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, please follow the steps below to modify your phone's settings:
1. Press MENU/SELECT.
2. Select the Global Setup menu, and then the Dial Mode submenu.
3. Scroll to highlight Pulse.
4. Press MENU/SELECT. You will hear a confirmation tone.
If you ever need to change the dial mode back to tone dialing, follow the same procedure, but select Tone in step 3.
Finally for future ease of use, here is a link to the user manual were I copied the above information from:
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1580-3om.pdf
Our phone says that we have a "message waiting" but we cannot access it. It says in our directions that we would have needed to set up a message system with another company which is something...
Your phone service provider is sending a signal on your phone line that is activating the message waiting on your phone. Likewise the beep-beep-beep you hear is called stutter dail tone which is sent by your phone service provider to indicate that you have a message in voicemail for phones that do not have message waiting or message waiting light ability. To cancel the message indicators, you'll need to call your phone service provider customer support and have them disable voicemail. Nowadays, voicemail service is often automatically added by service providers, especailly if you have recently changed service providers or your service provider has upgraded their switch equipment.
31helpful
I have a uniden dect1580 6.0 and the red light in the left hand corner blinks all the time.
That is the message waiting indicator, it is telling you that your Call Notes (Or whatever your service provider calls it's voicemail) has a message waiting. If you do not have a message waiting, you can turn the light of by following these steps:
When you receive a new voice mail message, the new message LED on the top of the handset flashes and
appears in the handset display. In the event your message waiting light gets out of sync with your phone company’s
voice messaging system, you can manually reset it back to the “No messages waiting” state.
Press and hold FIND on the base for five seconds.
1helpful
RCA Visys 25204RE1 Message indicator light not working
If it works sometimes, then it might be a problem with the phone or the phone line itself.
If it never works at all, then it's a problem with the services that the phone company has enabled/disabled on the line.
If that's the case, call your phone company's repair line and explain the situation. They can check to confirm that the message waiting indicator service is provisioned on the line, or add it if it's not.
Semi Dead Panasonic KX-TGA100N with ''C533'' displayed.
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
2answers
Samsung E900
Sound settings Use this menu to customise various sound settings.
Incoming call
Use this menu to select a volume level and alert type
for incoming calls.
Alert type: specify how you are to be informed of
incoming calls.
Ring tone: select a ringtone for the call ringer.
Volume: select a ringer volume.
Keypad tone
Use this menu to select the tone that the phone
sounds when you press a key.
Message tone
Use this menu to set up the ringtone for incoming
messages.
Menu functions
Tone: select one of several message tones.
Alert type: specify how you are informed when a
message comes in.
Repetition: specify how often the phone informs
you of a new message.
Power-on/off tone
Use this menu to select the melody that the phone
sounds when it is switched on or off.
Slide tone
sounds when you open or close the phone.
Silent mode
Use this menu to set how the phone acts to alert you
to a specific event in Silent mode.
Extra tones
Use this menu to customise additional tones for the
phone.
Minute minder: set the phone to beep every
minute during an outgoing call to keep you
informed of the length of your call.
Connection tone: set the phone to beep when an
outgoing call is connected to the system.
Alerts on call: set the phone to beep when you
receive a new message or when the time for an
alarm comes during a call.
Indicative tone: set the phone to beep when a
pop-up window displays.
Voice mail issue
Here is what is suppose to happen. Once you leave a message at Rogers, they are to send your phone a "stutter dial tone" signal back to your phone. When you phone gets this signal, it is to light your messag light. So we need to figure out if Rogers is sending the signal, and if your light is working. So, leave yourself a message. Give Rogers a minute or two to send the signal. Pick up your phone to make a call. Do you hear a "stuttery" type dial tone? If not, it sounds as if the Rogers system is not providing the signal. Okay, if your light is not on, then lets test the light by taking the Rogers VM out of the equation. Go to your Panasonic answering machine menu, and turn it on, then turn the number of rings set to 1, and save that. Now call the phone. It should answer after a ring or two, and your call should never make it to Rogers AM. Leave a message and see if your Panasonic answering machine takes the message and lights the light. If it does not light the light even though your message was recorded and saved, then you may have a bad light. If it lights the light, go back into your menu and turn the machine off, and look for any settings regarding using the "telephone company voice mail" or review your message light settings, etc. Hope this helps
Top Aastra Telecom Lands Phones Experts
k24674
Are you an Aastra Telecom Lands Phone Expert? Answer questions, earn points and help others
