Question about Maytag MMV4205 Microwave Oven
Door won't stay shut on a mmv4205BAW maytag microwave
    Top Expert:
  • Maytag Master
  • 55,370 Answers
Damaged or defective latch. Repair or replace.
Posted on Aug 06, 2019
6ya staff
SOURCE:
iaprogress
SOURCE: Sharp Carousel Microwave door latch stopped working door won't stay closed
Microwavesvc, that's what I've had happen with my sharp also, I carved a hook out of a piece of plastic and then epoxied it in, and haven't had any more problems with that.
Another problem I've had with the sharp (that just reoccured, I'm trying to figure it out) is that the micro-switches that the door latch push have gone bad. Originally just one went bad and I replaced it, now the micro has the light and fan on, and won't recognize being closed...
Posted on Jun 11, 2008
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: exaust fan has weak suction on maytage mmv4205baw
This is due to poor air flow, either to a blockage or a problem with the internal cooling fan or hood vent exhaust fan.
Are the grease filters or charcoal filter clogged?
You may want to check your owner's manual for info on checking the filters. Grease filters can be cleaned, but charcoal filters must be replaced about every 6-12 months.
The installation manual will tel you if there's some error in the installation setup.
You can download Maytag owner's manuals and installation instructions here.
Posted on Dec 13, 2008
James Chandler
  • 686 Answers
SOURCE: UMV1152BAB Maytag Microwave ... door look
REMOVE THE CABINET(COVER) AND YOU SHOULD BE ABLE TO SEE WHAT TO DO.
Posted on Apr 18, 2009
mohammed387
mohammed marika thambi
  • 1952 Answers
SOURCE: The door on my Microwave will not stay shut
replace torsion spring in micro door try this site
Posted on Sep 02, 2009
Stephen Lam
  • 670 Answers
SOURCE: Microwave no longer heats, makes more noise than
Sounds like the magnetron has failed. There are some high voltage circuits that feed the magnetron and you can potentially get hurt if you don't know what you are doing. Would recommend you have it serviced by a professional if you want it fixed, otherwise look for a new one since the cost of repair can come close to the price of a new microwave oven.
Posted on Dec 24, 2009
Testimonial: "Thanks, I talked to the manufacturer and they suggested the same. Thanks for taking the time to reply."
Maytag microwave turntable doesn't operate
Does everything else work?? If so, its just the turntable motor, simple to replace. there are three or four screws under the bottom. UNPLUG the microwave first.
Double check before ordering...but ..
Here is the one you need:
Turntable Motor DE31 10172C
Oct 01, 2017 | Maytag Microwave Ovens
Mmv4205baw parts
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor. See http://www.microtechfactoryservice.com/cap_test.html
If it went dead several seconds after pressing the Start pad, that's usually a failing high-voltage transformer. See: http://www.microtechfactoryservice.com/xformer.html
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount. See our help file on door switches here.
You can find helpful manuals, exploded views and parts lists here.
Our favorite supplier is the Pros here.
Jun 10, 2013 | Maytag MMV4205 Microwave Oven
Maytag microwave "turntable", light and cooling fan stay on after cooking complete.
you can leave the door ajar for a change - it also eliminates the odor inside the microwave
Oct 26, 2012 | Maytag JMC9158AA Microwave Oven
Door won't stay shut, microwave will not start
Contact the maker or Google the model number for "parts"
That part likely will require the unit to be taken apart to replace it.
Jun 16, 2012 | Jenn-Air Microwave Ovens
Maytag microwave MMV4205BAW interior fan continues to run when door is closed
One of the micro switches has malfunctioned, and must be replaced for normal operation.
Apr 02, 2012 | Maytag Microwave Ovens
Maytag MMV4205BAW not turning
Change the turn table motor part # DE31-10172B
Aug 18, 2011 | Maytag MMV4205 Microwave Oven
Display and touch buttons inoperative on MMV4205BAW Microwave Oven. Only abt 2 yrs old...
The keypad controller has probably developed a short in the membrane of the keypad, it must be replaced in order to get it up and running, but I suggest a maytag repairman to address this.
Feb 21, 2011 | Maytag MMV4205 Microwave Oven
I have a Maytag mmv4205baw Microwave oven. It
the unit that creates the microwaves called the "magnetron" has gone bad, or the circuits powering the magnetron have gone bad. there really isnt a cheap way to fix it, and not a undangerous way to fix it yourself. if your really like the microwave and dont want to part with it, you can try finding a repair shop that will fix microwaves, but they will probably tell you it would be cheaper to buy a new one. sorry
Jan 15, 2010 | Magic Chef CMV1000B Microwave Oven
Microwave no longer heats, makes more noise than it did when it was heating. Microwave is a Maytag, model # MMV4205BAW. Thanks.
Nov 27, 2009 | Maytag Appliances Over-the-Range Microwave...
Door handle broke off my microwave mmv4205baw
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Jul 29, 2008 | Maytag MMV4205 Microwave Oven
Maytag MMV4205 Microwave Oven Logo
370 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Paul Bade
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
