I have Pixma MP760 all-in-one printer, it prints ok, both document & photo untill yesterday when I started it, It shows ERRO the type of print head is not correct. Install the correct print head all of a sudden.
Here I
will show you where to find drivers and manuals for the Canon Pixma Mp760 photo
all in one printer.
Drivers for this printer are available for Windows
98, windows ME, windows Xp, Windows Vista, windows vista 64bit editions,
windows 7 and windows 7 64bit editions.
On the Mac side drivers are available for Mac OS X
10.2/10.3/10.4/10.5/10.6
A full on screen manual, quick start guide and
other instructions are also available.
To download these drivers and or documentation for
your printer please visitTHIS PAGE Note the picture reads MP730 but the actual linked page will be for your MP760 1. Click
on Drivers & downloads
2. Select your OS ( Operating system, windows, mac
etc )
3. All available drivers, documents etc will be
available below. For some of the documents a PDF reader may be
required to open and read / print them.
To obtain a PDF reader, read this pagePDF Documents. Pdf
reader(s) Thank you for reading and I hope your printer is
up and running again. -Ekse
Note: Properties may be indicated as Advanced, depending on the application software.
Click the Page Setup tab.
In the Printing Type section, select 'Normal-size Printing', 'Fit-to-Page Printing', 'Scaled Printing', or 'Page Layout Printing'.
Select 'Duplex Printing'.
Note:
When a media type other than Plain Paper, Photo Paper Plus Double
Sided, or Postcard is selected in the Media Type menu, duplex printing
cannot be performed.
Specify Staple Side.
The printer analyzes the Orientation and Page Layout settings, and automatically selects the best staple position.
Click the Staple Side drop-down arrow and select the
setting. If you want to change the setting, select another value from
the list.
If necessary, click Specify Margin... and set the Margin width
When the setting is completed, click the OK button at the bottom of the window.
Note: If a media type other than Photo Paper Plus Double Sided is selected for Media Type on the Main tab: The
document will be printed on one side of a sheet of paper when printing
starts. When printing is complete, reload paper according to the
displayed message and then click OK. The document will be printed on the
opposite side.
If Photo Paper Plus Double Sided is selected for Media Type on the Main tab: The
document will be printed front and back alternately for one sheet at a
time, when printing starts. Load the paper according to the displayed
messages.
You will be prompted, while printing, to remove the printed page and reload it in the ASF.
Dependent on the number of pages to print, you will need to repeat step 7 until all pages have printed.
Possible that the B&W ink cartridge is faulty or there is poor installation . You need to shut down the printer and remove the ink cartridge. now reinstall after ensuring that printer was disconnected and then connected.
Click on Start button Click on Run Type SERVICES.MSC and click ok look
for Print Spooler in the list highlight Print Spooler, Click on
STOP button then click on START close the window and check if the
print queue is gone.
Alternate method,
Click STart Click
RUN Type Cmd ( or COMMAND ) and hit enter In the black window
type NET STOP SPOOLER ( hit enter button ) Type NET START
Repeat the Stop and START Command
4-5 times End the Command with NET START SPOOLER
Open
Printers and faxes folder - Refresh the Window - the printer will show
STatus ready with 0 document
Hi there
Just take all your inks out then you will see the head take out the head by lifting the gray leaver up, gave it a good clean and put back it worth a try.
All the best Pineworks
