iRiver iFP-895 MP3 Player Logo
Posted on Sep 17, 2008
IFP-795 It is not getqing connected to my computer with Windows 2000.
Anonymous
Level 1:
  • Contributor 4 Answers
  • Posted on Jan 07, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
4855
Points
6
A) Have you tried finding updated Driver for your Windows2000?
b) Have you performed Firmware Update?
See Jan Karlsbjerg's blog at http://www.jankarlsbjerg.com/blog/archives/2007/03/26/ums-firmware-for-iriver-ifp-89x/
BUT NOTE, that Jan was talking about 895 model. Follow similar steps, but use firmware for YOUR 795 model (find it via web search).
Software for ifp-795
There isn't any need for any extra software with this unit. Once you plug it in to the computer you can just drag and drop the mp3's onto the "drive" or player.
Thank you,
Lee
10helpful
Need software for iriver 795 to download to mp3
drivers.myfreewares.com/freedownload-33086-iriver-ifp-790-ifp-795-ifp-799-mp3-player-firmware-v1.65-manager-version-download.html here you go :)
2helpful
WITH SERVICE PACK 3 (WIN XP) MY 795 IS "DISCONNECTED" NO MATTER WHAT! PLEASE HELP!!
The iFP-795 is a player that has connection type UMS
(also called MSC): seeing the player as a removable disk:
Go to next site to see the connection type:
http://www.iriver.com/flash/index.asp?code=0300
and click on connection. Scroll down to see the iFP-700 series listed in the connection type UMS.
UMS = Universal Mass Storage
MSC = Mass Storage Class
With XP sp3 the computer Operating System has setup USB connections with new drivers, that support both UMS (= MSC) and MTP connections.
MTP = Media Transfer Protocol
When you experience next making connection:
Connecting the device to the computer Wizard found new hardware pops up.
Only this time the Windows update searching for software will not work on automatic routine: ending up with "Cannot Install this Hardware".
Manual performing the wizard, setting the device to USB connection type:
1. Can Windows connect to Windows Update to search for software ?
Select "No, not this time".
[Next]
2. If your hardware came with an installation CD, or floppy disk, insert it now.
Select "Install from a list or specific location(Advanced)."
[Next]
3. Please use your search and installations options.
Select "Don't search I will choose the driver to install."
[Next]
4. Select the device driver you want to install for this hardware.
Select "USB Mass Storage Device."
[Finish]
Just post a comment if you need more help.
3helpful
2answers
Ifp 795 Cannot locate updated Driver for VISTA
Solution is given here and it works: I just did it for my beloved IFP-795...
http://iriverinc.com/vista/
Ifp-795
Do you have the music manager program in your system? If not, try to install it from your installation cd. If no cd, go to the iriver website and download and install the appropriate model software, in your case (ifp-795)
2helpful
DRIVER IRIVER ifp-790
Try here:
http://www.opendrivers.com/driver/233084/iriver-ifp-790-ifp-795-ifp-799-mp3-player-firmware-v1.85-ums-version-free-download.html
Mp3 player
Dear Bhuwan,
you can download the music manager software for your IFP-795 ,from this site:
http://www.iriveramerica.com/support/ultra/iFP-manager-pc.aspx
for download this software you have to just click on iriver Manager 3.16
Regards
Help pawn shop rapped me
Ok... You need only the iRiver Music Manager Here is a direct link for it. http://www.iriveramerica.com/download/iRiver_Manager_v316sp.exe Here is a link to Guide you for copying music using Windows Media Player 10 Only. http://www.iriveramerica.com/transfer10/ and here are the manuals you need.. The 7xx Series Maunal (Valid for all players starting with 7) http://www.iriveramerica.com/images/pdf/iFP-700EngPlayer.pdf The iRiver Music Manager Manaul http://www.iriveramerica.com/images/pdf/iMM_USA_040326.pdf Now this is what you need that was on the original CD Disk. Good Luck
Pawn shop deal went south
iriver.com has all the software availble to make it work on your p.c. Go to the website and search ifp-795. Download and install the software, you should be fine. You might be prompt in the instalation process... remember "install or continue anyway" good luck.
Top iRiver Audio Players & Recorders Experts
SmartAviator
SmartAviator
Mohammad Abumuailek
Mohammad Abumuailek
ExpressFiX
ExpressFiX
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
