D-Link DGL-4500 Wireless Router Logo
Anonymous Posted on Sep 20, 2011
How do i change my mtu settinggs - D-Link DGL-4500 Wireless Router
Robert
Level 2:
Habit-Forming:
  • Expert 64 Answers
  • Posted on Oct 16, 2013
 Robert
Expert
Level 2:
Habit-Forming:
Answers
64
Questions
0
Helped
91435
Points
157
To change the MTU rate on your router follow the steps below:
Open your browser, enter the IP address of your router (192.168.0.1) and click OK.
Enter your username (admin) and password (blank by default).
Click OK to enter the web configuration page for the device.
Click on Setup and then click Manual Configure.
To change the MTU enter the number in the MTU field and click Save Settings.
If changing the MTU does not resolve the problem, continue changing the MTU in increments of ten.
1500 is the default MTU for Dynamic (DHCP) Cable (p. 20 in user manual).
1492 is the default MTU for PPPoE (Point to Point Protocol over Ethernet) DSL (p. 22 in user manual).
Other MTU settings are listed in the manual, simply do a search for "MTU".
Note: AOL DSL+ users must use MTU of 1400.
To find the proper MTU Size, you'll have to do a special ping of the destination you're trying to go to. A destination could
be another computer, or a URL (p. 86 in user manual).
Here is the PDF link to the User Manual:
http://www.dlink.com/-/media/Consumer_Products/DGL/DGL%204500/Manual/DGL%204500_Manual_EN_US.pdf
1helpful
How do i increase my mtu on my d link dir 655 router?
• Open your browser, enter the IP address of your router (192.168.0.1) and click OK.
• Enter your username (admin) and password (blank by default). Click OK to enter the web configuration
• Click on Setup and then click Manual.Configure.
• To change the MTU enter the number in the MTU field and click Save.Settings to save your settings.
• Do a test. If changing the MTU does not resolve the problem, continue changing the MTU in increments of ten.
1500 is default
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
2helpful
I need to change the MTU settings
To change your MTU settings download a program called DrTCP (google for it) then change the MTU size of your Internet connection, try 1465 and keep dropping it until you get a figure that works...
You can also check out xbox support site for more information on MTU settings here
1helpful
What is the mtu and can it be changed?
To change the mtu you have to login to the web page of the modem and from there you will have an option to change the mtu. The default will be 1492 , change that to 1400 or 1358 for reliable communication with the x-box.
1helpful
Mtu setting
In some cases, MTU is not necessary to adjust. Its always automatic and defaulted to 1500. The router model that you have doesn't have MTU settings. You can download the User's Manual HERE. You must do port forwarding and open the xbox live port so you can play xbox live. If it keeps on telling you about MTU, you must set static IP address on your xbox's settings and power cycle your devices.
Xbox 360 mtu how do I change mtu on my DLINK ADSL2
I have the same problem, call the support line or resort to this website it helped me a lot... http://help.expedient.com/broadband/mtu.shtml
Needs to know more about MTU size changes
Changing the MTU size to any "small" value is a bad idea -- compare it to running to the corner store every time that you need to take anything (milk, ice-cube) out of your refrigerator -- the "time" to go back-and-forth to the store (or the Internet) will be excessive, and "slow" down your productivity.
Mtu
The modem (westell wirespeed)you have does not have is a old modem... that does have options to set the mtu settings. You need to change the modem. By the way why you need to set the MTU settings,.
MTU
MTU, Partial Loss of Internet Connection, and Performance MTU (Maximum Transmission Unit) is the largest packet a network device transmits. The best MTU setting for NETGEAR equipment is often just the default value. MTU is sometimes presented as something that can be easily changed to improve performance, but in practice this may cause problems. Leave MTU unchanged unless one of these situations applies: 1. You have problems connecting to your ISP or other Internet service, and their technical support (or NETGEAR's) recommends changing MTU. For example, these services may require an MTU change: * Yahoo email * MSN * AOL's DSL service 2. You use VPN, and have severe performance problems. 3. You used a program to "optimize" MTU for performance reasons, and now you have connectivity or performance problems. * An easy solution to most problems is to change MTU to 1400. * If you are willing to experiment, gradually reduce MTU as described in "Details of MTU", below. How to Change a Computer's MTU Size Note: If you change MTU on one computer, it is likely you will want to change it on your other computers, switches, and routers, as well. Instructions for changing MTU on other NETGEAR devices is found in the Reference Manuals. The third party Dr. TCP software can be used to change the MTU setting. 1. Download it from this link, choosing the zip file or the exe file at the top of the page. 2. Run the utility. 3. In the Adapter Settings pull down, select the Ethernet driver and adapter used to connect with the network. 4. In the MTU box, type the MTU size you are trying. 5. Click in any other box, without changing the data there. 6. Click Save. 7. Click Exit. 8. Restart the computer. Details About MTU A packet sent to a device larger than its MTU is broken into pieces. Ideally, MTU would be set to the same ? large ? value on all your computers, routers and switches, as well as on all the parts of the Internet that you access. But you cannot control the MTU on the Internet, and in practice the optimum MTU size on your LAN is related to your hardware, software, wireless interference, etc. * Tweaking MTU size may work well in one situation, but cause performance and connection problems in others. * When network devices with different MTU settings communicate, packets are fragmented to accommodate the one with the smallest MTU. * Windows XP sets MTU automatically, that is, it optimizes computer MTU for you. This Microsoft article explains resolving lack of connection to a broadband ISP using Windows XP: http://www.microsoft.com/windowsxp/using/networking/learnmore/ppoe.mspx * Once a network device fragments a packet, the data stays fragmented until arriving at the destination computer. Setting MTU size is a process of trial-and-error: start with the maximum value of 1500, then reduce the size until the problem goes away. Using one of these values is likely to solve problems caused by MTU size: * 1500. The largest Ethernet packet size; it is also the default value. This is the typical setting for non-PPPoE, non-VPN connections. The default value for NETGEAR routers, adapters and switches. * 1492. The size PPPoE prefers. * 1472. Maximum size to use for pinging. (Bigger packets are fragmented.) * 1468. The size DHCP prefers. * 1460. Usable by AOL if you don't have large email attachments, etc. * 1430. The size VPN and PPTP prefer. * 1400. Maximum size for AOL DSL. * 576. Typical value to connect to dial-up ISPs.
Connection problems
The current firmware allows the maximum transmission unit to be changed if needed. If you are having a problem sending or receiving email, or connecting to secure sites such as eBay, banking sites, and Hotmail, we suggest lowering the MTU in increments of ten (Ex. 1492, 1482, 1472, etc). What is my MTU? - To find the proper MTU Size, you?ll have to do a special ping of the destination you?re trying to go to. A destination could be another computer, or a URL. Step 1 Click on Start and then click Run. Step 2 Windows 95, 98, and ME users type in command (Windows NT, 2000, and XP users type in cmd) and press Enter (or click OK). Step 3 Once the window opens, you?ll need to do a special ping. Use the following syntax: ping [url] [-f] [-l] [MTU value] Example: ping yahoo.com -f -l 1472 You should start at 1472 and work your way down by 10 each time. Once you get a reply, go up by 2 until you get a fragmented packet. Take that value and add 28 to the value to account for the various TCP/IP headers. For example, lets say that 1452 was the proper value, the actual MTU size would be 1480, which is the optimum for the network we?re working with (1452+28=1480). Once you find your MTU, you can now configure your router with the proper MTU size. Note: AOL DSL+ users must use MTU of 1400. To change the MTU rate follow the steps below: For the DI-514, DI-524, DI-604, DI-614+, DI-624, DI-754, DI-764, DI-774, and DI-784: Step 1 Open your browser, enter the IP address of your router (192.168.0.1) and click OK. Step 2 Enter your username (admin) and password (blank by default). Click OK to enter the web configuration page for the device. Step 3 Click on the Home tab and go to the WAN tab. Step 4 The default MTU is 1500, to change this enter the number in the MTU field and click the Apply button to save your settings. Step 5 Test your email. If changing the MTU does not resolve the problem, continue changing the MTU in increments of ten. Note: If you have the European version of the DI-604, this procedure will not work. If you do not have an MTU option, please upgrade your firmware.
Connection problems
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
