Computers & Internet Logo
Posted on Sep 20, 2011
I install TI Interactive on a Vista machine, and it works ok. Then i log on as another user and copy the install users profile to default, but when i then logon as a third user get this message. TI InterActive! MFC Application has stopped working.
2 Related Answers
Anonymous
  • 1901 Answers
  • Posted on Dec 30, 2008
SOURCE: I need a stylus pen for a Leapfrog interactive globe
Simply call Consumer Services at 1-800-701-5327 to order a new pen.
brumed
  • 8 Answers
  • Posted on Dec 19, 2009
SOURCE: TI Interactive will not install on windows 7. It
Try doing a "silent" installation.
Click the Start button
Click the Run button
Type cmd then press enter
In the command box type the drive letter for your CD Rom Drive, followed by a colon (example, D:) then press enter
Type tiinteractive.exe /quiet then press enter
Wait 5 minutes then close the command box
TI interactive should be now installed
If it doesn't work, e-mail me at [email protected]
Toshiba satellite c660-2el administrator cannot log on, user profile service failed to log on, user profile cannot be loaded
Your profile is probably corrupted. You will need to log in another account that has administrative permissions and rename the "administrator" profile to "administrator.old". After doing that, try logging in again to the administrator profile and copying all the data from the old profile to the new one that was created. If you still get the same error or if there are no other users that have administrative privileges, you will need to do a repair installation (Windows XP) to fix this. If you are using Windows Vista or higher, you will have to install over your existing installation to preserve your data, or do a clean install (format) and start new. This is actually a common problem, so don't blame yourself.
tip
How to copy data from a corrupted user profile to a new profile
Create a New User Profile in Windows XP Professional loadTOCNode(2, 'moreinformation'); 1. Log on as the Administrator or as a user with administrator credentials. 2. Click Start, and then click Control Panel. 3. Click User Accounts. 4. Click the Advanced tab, and then click Advanced. 5. In the left pane, click the Users folder. 6. On the Action menu, click New User. 7. Enter the appropriate user information, and then click Create
Create a New User Profile in Windows XP Home Edition loadTOCNode(2, 'moreinformation'); 1. Log on as the Administrator or as a user with administrator credentials. 2. Click Start, and then click Control Panel. 3. Click User Accounts. 4. Under Pick a task, click Create a new account. 5. Type a name for the user information, and then click Next. 6. Click an account type, and then click Create Account
Copy Files to the New User Profile loadTOCNode(2, 'moreinformation'); 1. Log on as a user other than the user whose profile you are copying files to or from. 2. In Windows Explorer, click Tools, click Folder Options, click the View tab, click Show hidden files and folders, click to clear the Hide protected operating system files check box, and then click OK. 3. Locate the C:\Documents and Settings\Old_Username folder, where C is the drive on which Windows XP is installed, and Old_Username is the name of the profile you want to copy user data from. 4. Press and hold down the CTRL key while you click each file and subfolder in this folder, except the following files: • Ntuser.dat • Ntuser.dat.log • Ntuser.ini 5. On the Edit menu, click Copy. 6. Locate the C:\Documents and Settings\New_Username folder, where C is the drive on which Windows XP is installed, and New_Username is the name of the user profile that you created in the "Create a New User Profile" section. 7. On the Edit menu, click Paste. 8. Log off the computer, and then log on as the new user.
tip
Create a duplicate user profile with a different name
To create a duplicate of an user profile with a different user name, try this:
  • Create a new user account
  • Logon to that account to initialize the newly created profile
  • Log off from the newly created profile
  • Login as built-in Administrator
  • Open Control Panel System applet
  • Click the Advanced tab
  • Click Settings under User Profiles
  • Select a profile to copy from and choose Copy To
  • Browse to the profile to copy to (C:\Documents and Settings\username)
A new profile is now created which is the duplicate of your user profile.
3answers
When i try to log-on i put my pasword into the box and says "the user Profile Service service failed the log-on.User profile cannot be loaded. what do i do
To resolve this problem open yourself, follow these steps:
Right click Computer > Properties > Advanced system settings > Advanced tab > Under User Profiles, click Settings > In the User Profiles dialog box, select the profile that you want to delete > click Delete > Apply/OK.
Next open regedit and navigate to the following key:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList
Right-click the SID that you want to remove, and then click Delete.
Log on to the computer and create a new profile.
Alternatively, you can simply download and use this Fix It 50446 from Microsoft given on KB947215.
You may also want to check out ReProfiler. It is a freeware tool for manipulating user profiles on Windows 7, Vista, XP, 2000, Server 2003 & Server 2008.
OR
you can try with the following link
http://support.microsoft.com/kb/947215
Thanks
Sandeep
1helpful
2answers
I recently had a virus on my computer. I had a friend who is a computer tech get rid of the virus but had to start my computer over from scratch. When I started downloading files and programs I noticed...
I think from what you have said is simply the problem of User Accounts. Simply Open the User Accounts option from the Control Panel and go to Make changes to your User account and simply change the name of the User account. Put your name there instead of your friend's. Actually this wasn't a problem but a feature provided by the Windows so that many users can actually work on their own account on a particular system thus protecting the data from each other. There you go. The account will now have your name. The folder with your name will be shown in the start dialog or the desktop.
tip
This article describes how to copy user data from your Windows XP profile to a new profile.
When you copy user data into a new profile, the new profile becomes a near duplicate of the old profile, and contains the same preferences, appearance, and documents as the old profile. If your old profile is corrupted in some way, you can move the files and settings from the corrupt profile to a new profile.
Note The method that is described in this article may not transfer the Outlook Express e-mail messages and address user data that are associated with the user profile where you are transferring data from. When you delete the old profile, you may delete that data if it you do not first transfer it by using other methods. For more information about transferring Outlook Express user data, click the following article number to view the article in the Microsoft Knowledge Base:
MORE INFORMATION
7. Enter the appropriate user information, and then click Create.
6. Click an account type, and then click Create Account.
• Ntuser.dat.log
• Ntuser.ini
I want to change my laptop's language from english to russian without formatting
Windows XP: How to change the Default User UI LanguageIn Windows XP, you can set the UI language that the default user on the local machine (or a domain user that doesn't have a profile) will see at first first log on. It is also the UI language that is applied to system services running on local machine.
• Open Regional Options in Contol Panel
• Click on the Advanced tab
• In "Default user account settings" at the bottom of the page, check the box beside "Apply all settings to the current user account and to the default user profile"
WINDOWS VISTA/7
  1. Open Regional and Language Options by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Clock, Language, and Region, and then clicking Regional and Language Options.
  2. Click the Keyboards and Languages tab.
  3. Under Display language, choose a language from the list, and then click OK.
HOPE THIS HELP,
CHEERS
I have lost my personal profile on windowes vista
all you can do is go control panel then user accounts to add a new user account and profile.
I have a dell latitude d610 lap top
Based on the build of a D610, I am assuming you're running Windows XP. I'm not sure your hardware can support Vista. That model was built before Vista was available.
That said, go to Start-Control Panel-User Accounts. Most likely a setting in there was changed, and my first thought is that it may have been after a Windows Update, in an effort to increase security.
See if the user you're trying to login with even shows on the list. If it does, click on it and change the password to <blank>.
If that user no longer shows then you will have to rebuild the profile for that user. I will caution you that if you have to rebuild the profile, you would want to make copies of the data attached to the old profile. You can do this from Windows Explorer. Start by making sure you can view all files. Then navigate to Local Disk C:-Documents and Settings, then to the folder for that username. Copy all of the folders and files to a safe place, like burn it to CD's or DVD's, or even to a flash drive. Do not save it to My Documents.
Sometimes the fastest way to rebuild the profile is to actually create a new one. Set it to administrator access. Then you can copy the contents of your old user's folders (but not the folders themselves) into the new user's folders.
Here's a recap:
1. Log in as admin or an account with admin permissions.
2. Select the windows START button and click CONTROL PANEL
3. Click USER ACCOUNTS
4. Select CREATE A NEW ACCOUNT. You may need to select pick a task first
5. Type in a new name for the account
6. Click create account and ensure it is an admin account.
4. Press and hold down the CTRL key while you click each file and subfolder in this folder, except the following files: Ntuser.dat, Ntuser.dat.log, Ntuser.ini
3answers
The computer won't log me on.
Make a backup copy of all your data, including passwords, emails, settings, etc
Find another windows xp computer whether its a friends or another computer you have and get a memory stick or external hard drive ( which you will need ) on the working computer go into
c:\documents and settings
make a copy of the default user folder and copy that over the one on your laptop and try again.
I rebooted my system in 'safe mode' (which allowed me to login as
administrator), moved my files to the public area, and then deleted my
profile (using the Users option in Control Panel).
When I rebooted again, in normal mode, I could login as administrator, and
then moved my files back and rebuilt my profile manually.
The only problem was my forgetting about e-mail messages, which I did not
backup and have been lost permanently. Ug!!!
http://cherrybyte.blogspot.com/2007/07/fixing-user-profiles-in-vista.html
Top Texas Instruments Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Texas Instruments Computer and Internet Expert? Answer questions, earn points and help others
