Intel D102GGC2 Motherboard Logo
Posted on Sep 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Give me the some example of 64 bit operating system and what is the hardware config. to run them like how much ram requierd.
Creative Tech
Level 3:
  • Master 1,719 Answers
  • Posted on Sep 20, 2011
Creative Tech
Master
Level 3:
Answers
1719
Questions
Helped
635753
Points
5906
Windows Operating System comes in both 32-bit and 64-bit versions. Examples are Windows XP (64-Bit) and Windows 7 (64-Bit). A 64-Bit Operating System is capable of handling large amounts of data. Hence, it is clear that newer hardware supports 64-bit operation. As for processor Core 2 Duo or higher is required with RAM at least 2 GB or more.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Install autodesk maya 2010 64bit
Okay the first thing even though your question is very general and we really don't know the specific probably having if you're installing an auto 64-bit you need these operating systems listed below make sure you have one of those operating systems it must be 64-bit you need to check if your operating system is 64-bit before you can stop go to the Run command on your operating system and type winver then enter an then enter and see if and seethe computer is if the computer64bit if it is not 64-bit you need a 64-bit computer first and foremost if you're having other problems you need to give us more details before we can help
If you're having a license key issue you may not actually own software or maybe counterfeit you need to contact Autodesk in that case good luck
The 64-bit version of Maya 2010 software is supported on any of the following operating systems:
  • Microsoft Windows Vista Business (SP1 or higher)
  • Microsoft Windows XP x64 Edition (SP2 or higher)
  • Red Hat® Enterprise Linux® 5.3 WS operating system
  • Fedora™ 8 operating system
The following web browsers are supported for Maya 2010:
  • Microsoft® Internet Explorer® 6.0 internet browser or higher
  • Netscape® 7 web browser or higher
  • Apple® Safari® web browser
  • Mozilla® Firefox® web browser
Hardware
At a minimum, the 32-bit version of Maya 2010 software requires a system with the following hardware:
  • Windows: Intel® Pentium® 4 or higher, AMD Athlon™ 64, or AMD Opteron™ processor
  • Macintosh® computer: Intel-based Macintosh computers
  • 2 GB RAM
  • 2 GB free hard drive space
  • Qualified hardware-accelerated OpenGL® graphics card
  • Three-button mouse with mouse driver software
  • DVD-ROM drive
  • Maya Composite media cache requirements for playback:
  • 10 GB minimum, 200 GB recommended
  • HDD: IDE, SATA, SATA 2, SAS, SCSI
At a minimum, the 64-bit version of Maya 2010 software requires a system with the following hardware:
  • Windows and Linux: Intel® EM64T processor, AMD Athlon 64, or AMD Opteron
  • 2 GB RAM
  • Qualified hardware-accelerated OpenGL graphics card
  • DVD-ROM drive
If i update my cpu to t7800 will it give me more max ram its got the t7100 in it at the moment with 2 slots. 2x2gb ram max 4gb or do i need to incress the cores to get more ram and if so can u tell me a...
The cpu speed does not affect the amount of usable RAM.
If the motherbaord is designed to take more than 4gb, it can be installed, but will not be used if the operating system is 32 bit.
To use more than about 3.5gb you have to have a 64 bit operating system. For example, my PC motherboard has slots for 8gb and I have 4gb installed, but the system only uses 3.25gb because my operating system is 32 bit XP.
1helpful
What kind of Pc station compact to dell 755
Hmmm, here we are again.
Between this question, and the other question you posted, are you asking what kind of Ram Memory to use?
DDR2 Sdram at 667Megahertz, or 800MHz.
That is PC2-5300, or PC2-6400.
The Maximum TOTAL Amount of Ram Memory for the motherboard, is 8GigaByte. (8GB)
This is ONLY if you are using an Operating System that is 64-bit.
(Examples; Windows XP 64-bit, Windows Vista 64-bit, Windows 7 64-bit )
Using an Operating System that is 32-bit, the realistic figure is more like 3GB to 3.5GB.
EVEN if you have 4GB of Ram Memory installed.
IF, this is not what you need meazaw, post back in a Comment.
Regards,
joecoolvette
Can i install windows 7 on acer veriton 7500g
Your Pc should meet the following hardware requirements in order to run Windows 7
  • 1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor
  • 1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit)
  • 16 GB available hard disk space (32-bit) or 20 GB (64-bit)
  • DirectX 9 graphics device with WDDM 1.0 or higher drivers
I googled your pc model and found that you just need to install extra RAM (if your PC have less than 1 GB RAM).
2answers
How can i use the 4GB ddr ram? still on 2GB while it has 4GB.. it said that only 2GB usable.
The 2nd 2Gb RAM module may be faulty or not compatible with the other RAM module.
Try inserting one RAM module in the notebook at a time to determine which RAM module is faulty.
If both RAM modules work then make sure both RAM modules are the same make and speed.
2answers
I installed 4 Gig of RAM memory but only 3.25 shows up.\r\nis there a test I can run to see if the memory cards are working correctly? Thanks. Paul
It sounds like you are running a 32 bit operating system XP, Vista, or Windows 7 (32).
The 32 bit Operating Systems are only able to see and use about 3Gb of RAM. To use a greater amount you will need a 64 bit OS (either Windows XP/64 or Windows 7/64) or one of the open source 64 bit operating systems.
1helpful
4answers
How to check weather computer will support 64 bit
Open the "System Properties" window
If your Start menu is configured for Classic Start menu, right-click the My Computer icon on your desktop, and click Properties.
If your Start menu is the Windows default Start menu, click the Start button, then right-click the My Computer icon in your Start menu, and click Properties.
Click the Advanced tab.
Click Environment Variables.
In the "System variables" list at the bottom of the Environment Variables window, look for a variable called "PROCESSOR_ARCHITECTURE". If your PC has a 32-bit processor, this variable will have a value of "x86". If it has a 64-bit processor this variable will have a value of "x64".
Best operating system for new build?
Either Windows XP or Vista 64 bit edition, depending on what you like...I won't get into the xp vs. vista battle here lol. The 64 bit operating systems can see all of your memory, with the 32 bit OS's, you're limited to around 3 or so gigs. Do note, that there may be some incompatibilities with a 64 bit operating system, though most programs should run fine.
Application Error
better uninstall the program and reinstall it..
Minimum System Requirements
Software
The 32-bit version of Autodesk 3ds Max 2009 is supported on any of the following operating systems:
* Microsoft® Windows Vista® operating system
* Microsoft® Windows® XP Professional (SP2 or higher) operating system
The 64-bit version of 3ds Max 2009 is supported on any of the following operating systems:
* Microsoft Windows Vista
* Microsoft Windows XP Professional x64
3ds Max 2009 30-day trial version requires the following browser:
* Microsoft® Internet Explorer® 6 or higher internet browser
3ds Max 2009 30-day trial version requires the following supplemental software:
* DirectX® 9.0c application programming interface (required)
* Some features of 3ds Max 2009 software are only enabled when used with graphics hardware that supports Shader Model 3.0 (Pixel Shader and Vertex Shader 3.0). Check with your manufacturer to determine if your hardware supports Shader Model 3.0.
Hardware
At a minimum, 3ds Max 2009 32-bit requires a system with:
* Intel® Pentium® 4 or AMD Athlon™ XP or higher processor
* 512 MB RAM (1 GB recommended)
* 500 MB swap space (2 GB recommended)
* Hardware-accelerated OpenGL® application programming interface and Direct3D® application programming interface supported
* Microsoft Windows – compliant pointing device (optimized for Microsoft IntelliMouse)
* DVD-ROM drive
Note: Apple® computers based on Intel processors and running Microsoft operating systems are not currently supported.
At a minimum, 3ds Max 2009 64-bit requires a system with:
* Intel EM64T, AMD Athlon 64 or higher, AMD Opteron™ processor
* 1 GB RAM (4 GB recommended)
* Hardware-accelerated OpenGL and Direct3D supported
* Microsoft Windows – compliant pointing device (optimized IntelliMouse)
* DVD-ROM drive
Top Intel Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
