SOURCE: Wireless installation for DCS-5220
check wep and wap security in your camera.
check if your wireless signal is good
SOURCE: DCS-3420 SecuriCam Install
Normal 0
Did you install the software with the camera connected tothe computer? Disconnect the camera from the USB port and reinstall thesoftware. When the program asks you to connect the camera, do so, and itshould work. Hope this is of some help. Bud
Below is info for setting up Audio & Video to chaton line after you install , either Skype or a messenger program.
SOURCE: D-Link DCS-5220 - Wireless connection constantly dropping
If you have configured Motion Detection then your problem may be because the camera only turns on when motion is detected. That is why it will seem as if the camera is dropping the connection.
If motion detection is not configured then you may be experiencing the same thing I have experienced. The camera does not record in full real time. It only gets snippets of information so the subject seems to jump from one place to another if they move fast. I guess this is a feature of IP cameras because they need to pass through the network with a lot of overheads. This is where good old CCTV cameras with their coaxial cables are best. They may be more difficult to install because of the cabling but their performance is a lot better
SOURCE: DCS-1000w through Dlink DIR-655 router
These cameras are touchy. Hold the reset button on the back in for about 20-30 seconds. Bring up the CD software you got with the camera, it should spot the camera right off and you can configure. That seems to be the only way I can communicate with this model. After setup, then browsers, etc seem to work fine. I would also download the latest Firmware and update.
click start type cmd press enter you will be in DOS mode
type in ipconfig press enter
you will see all o fyour internet connection details type in your default gateway adress into your internet search should read something like 10.0.0.138
Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabledimake sure its enabledPci device
hope this helps
