Error says, " The layout you have selected cannot be loaded. Please select a different layout using the Home Screen item in Settings." The screen is white with black print reading this, and shows nothing else. It just came up with no warning. When I try to go to the home screen settings, there is nothing for me to choose from anymore. All the categories are blank. Help!
SOURCE: Samsung Blackjack display error
This is a fairly rare problem, but it does happen with the Blackjack and other Windows Mobile devices.
First thing to try is:
Start -> Settings -> Display -> Home Screen -> (your carrier) Default
If this option or no options are visible, attempt to move right or left a couple of times (if you are in the list mode, move up and down) and then hit 'OK'
If this does not work, you will need to do a factory restore on your device:
WARNING - Restoring the factory settings on your device may cause the loss of all of your data that is not stored on the memory card or backed up elsewhere. Please back up your data before doing a factory reset and remove your memory card during the procedure:
From within the Software:
1. Start -> Settings -> More -> SECURITY -> More -> Reset
2. Enter '0000' and hit 'OK'
From the Powered off state:
1. Power off the device
2. Hold down the 'UP' navigation arrow while pressing the power button.
3. You will be presented with a 'format' menu, hold
