Its just the nail polish,
Well, if you have this problem with all nail polish, then you can safely assume that the problem may be that you have oily nails - in which case your nails will secrete oils that lift the nail polish off your nail, causing it to chip.
BUT
If you are only experiencing this problem with this particular bottle of Salley Hansen, then it is likely that it may be a formula problem.
For both instances, try using a primer and a base coat polish BEFORE applying the Sally Hansen. This will improve the adhering of the polish to your nail no matter what the problem is.
