Question about Targus PAUH217U 4-Port USB Hub
Hi there I have a Targus 4 port smart usb hub which they say is a plug and play device but does not play when connected to my Toshiba Satellite Pro A200 laptop? What do I need to do to make it work? I find I have this problem with any usb hub connected to this computer...Please help. Kathy
  • 12,061 Answers
Hi you may need to install the driver for that "Hub" also make sure that it is compatible with your system? make sure that the unit is USB compatible, usually it must be a USB 1 or USB2 version.. but in any event when it is first plugged in there should be a **** **** noise that indicates that it has been inserted, Windows should then detect it and install the necessary hub drivers, if it doesn't do so, then you may have to upgrade your USB layer? Do you have all service packs installed?, or even perhaps remove and reinstall the USB layer, to do this go to control panel, and then system, then device manager, find the USB part and right click on it and REMOVE everything and reboot, then windows will reinstall the layer again, and now you should be able to insert the Hub and it should be detected, have the driver install and work.
Also have a look at these troubleshooting links below they will assist you too..
http://support.microsoft.com/kb/310575
http://webcache.googleusercontent.com/search?q=cache:bUVhSp2zU3QJ:www.earthtym.net/USB-solutions.htm+troubleshooting+usb+ports&cd=3&hl=en&ct=clnk&gl=nz
Posted on Sep 19, 2011
6ya staff
SOURCE:
Targus pa055 manual
These are just plug and play. No instructions required.
Jan 27, 2013 | Targus Ultra Mini PA055U 4-Port USB Hub
Targus 4-Port not working
First off hubs don't support a lot of power hungry devices so you should be able to buy an optional power adapter for the hub on targus' site.
Second if your computer doesn't have any usb 3 ports then the hub will only operate at usb 2 speeds.
Your probably overloading the hub. Buy the power adapter.
Dec 22, 2012 | Targus 4-port USB Hub Group International...
Ports/Interfaces on Toshiba Satellite Pro C660-171
If you still have warranty, take it back asp, they will have to repair or replace since this was manufacture defect, if that is not an option! Do a complete recovery on your operational system to factory setting.
Mar 21, 2012 | Toshiba Satellite Pro 6000 Notebook
I plug in the 4 port usb targus and it doesnt respond
sometimes you have to plug a usb into these to get them to respond if this does not work try plugging it into another USB port. If this does not work than look at the wires they may have come unattached
Jan 22, 2011 | Targus 4PORT USB 20 TRAVEL HUB ACH7405US...
I bought a 4 port usb hub targus and it doesn't work with my windows 7
Right click on my computer or the icon for my computer and select manage then open device manager and see what it says in there then up top select check for hardware changes icon, this should look for and install the hub
Jan 01, 2011 | Targus PA055U 4-Port USB Hub
My Targus keeps disconnecting what is connected to it then will reconnect (seems random) anyone else having problems with disconnecting devices plugged into the hub? Model ACH7405US
This USB hub is not powered by an AC adapter. Therefore, some devices that need more power will not work well on it. You don't mention what it is you are pluggin into it, but I suspect this may be your problem. Devices like webcams pull way too much to be on a hub without AC.
Did I solve your problem? If so, please rate this. ty.
Feb 26, 2010 | Targus PAUH217U 4-Port USB Hub
My USB Port stopped recognizing my Smart Disk
on my computer right click and select properties, then go to the device manager. Under the USB device locate this device and delete and unplug the cable from the computer. Let the computer reboot, and plug the cable into another port if ava. and see what happens.
Oct 10, 2009 | Targus PA050U 4-Port USB Hub
Targus Travel USB 2.0 4-port Hub
sometimes usb hard drives will not work through a usb hub.
if the drive works connected to the laptop but not the hub then that's how you'll have to use it.
it's also possible the laptop cannot power both the hub AND the drive, in whaich case you'll need a powered hub (one you plug in to the mains).
Sep 21, 2009 | Targus PAUH217U 4-Port USB Hub
Power supply for Targus 4 hub usb 2
Most USB hubs do not need an external power supply, except when a connected USB device draws more power than the computer/laptop USB port can supply. In this case an external power supply will need to be connected to the USB hub.
Normally this would be a 5 volt power supply, but make sure the polarity on the connector matches the power connector on the hub, check the label on the hub, sometimes it states to power requirements of the hub as well as the polarity on the connector. Normally the pin on the hub's power connector is positive (ie. +5V)
Nov 13, 2008 | Targus PAUH217U 4-Port USB Hub
Targus PAUH217U 4-Port USB Hub Logo
122 people viewed this question
Top Targus Computers & Internet Experts
Raj Patel
Andrew Taylor
Andrew Taylor
Are you a Targus Computer and Internet Expert? Answer questions, earn points and help others
