SOURCE: My bath tub with jets hums and I can't find an access panel.
The pump is usually at the side/rear of the tub, opposite the drain, the faucets can be mounted anywhere, but usually over the drain. The panel could be tiled, and just grouted in, if it is not exposed, try tapping on it to see if it sounds different in spots. Who knows, it might just fall out. How about behind the back wall?? Closet? Access? There is no electrical parts in there to repair, Pretty sure it is just the motor. and a bunch of pipes glued together and stuck through the tub. Did you fill the tub with water before trying the jets? Just checking. Hope this helps.
SOURCE: when I push the button to start the jets, it just
there may be something caught in the impeller in the jet motor. remove it and clean it out.
SOURCE: I bought a house with a american standard jet tub
yes. You will find a replacement pump at the following stores:
US Parts Center
Bath Parts Plus
