I have a JVM1850 White microwave-over the oven-installed 3 years ago. Last evening the unit would not turn off. The inside light and fan continued to run, however, the microwave was not working.
All the controls and functions seem to operate, but when completed, the unit remained working, as stated above, with the door opened or closed.
SOURCE: microwave message says to replace
External vent systems have the charcoal filter removed, generally at the time of installation, as it is not needed for this application.
The charcoal filter removes odors from internal recycled airflow.
There should be an aluminum grease filter that you can remove to clean in a warm soapy solution, let dry, and reinstall.
SOURCE: purchased a microwave model JVM1750DMIBB
Thank you for responding - we visited our local HHgregg store for clarification of our 'problem'.....
SOURCE: GE Microwave JVM1850 Does not heat food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
jjs
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
