Hello, This dishwasher has the ability to be mounted to the cabinets on either side of the dishwasher.the mounting brackets can be moved to each side. If it must be mounted to the counter top, the mounting tabs can be bent by hand and it will break the front part of the mounting tab. This will shorten the mounting bracket. If you have granite counter tops do not attempt to drill into to the granite counter call a granite fabicator. The leveling feet are hexagon shaped at the top of the of the leveling leg. Remove the front lower toe kick panel. This will allow access to the top of the leveling legs,then use a small cresent wrench or a socket and rachet.Hope this helps.Joe Connolly
Place the level on the top of the washing machine to see if it is level. Make sure you test it side to side and front to back.
Pull the washing machine away from any walls if you have to make an adjustment to the legs.
Lift the washer and place the wood block underneath the washer. Place the block near the leg that needs to be adjusted, but don't let it obstruct the leg.
Loosen the nut that secures the leg with the wrench.
Raise the height of the leg by twisting it to the left, or lower the height by twisting it to the right.
Remove the block of wood from under the washer and recheck the machine with the level.
Raise or lower the leg if additional adjustments are needed.
Tighten the nut on the leg with the wrench when the machine is level.
Repeat the process for each leg that needs to be adjusted.
Move the washer back into position and check with the level again to make sure the washer remains stable to finish leveling the machine.
Regards,
Richard Roth
http://appliancecafe.com
