trick question, which pneumatic tools used are part of the equation as for terms such as cfm, volts, amps, horse power, and resources available.
A 5 cfm compressor will not operate efficiently a 8 cfm tool. A 5 HP compressor needs plenty of power, a 30 amp 220 volt circuit, try finding a 5 HP 120 volts compressor.
depending on power available, tools selection then a compressor size can be selected.
The two most important specs are CFM at 90 psi (that's how fast the compressor can compress more air when the tank starts to run low) and how big the tank is. Virtually any compressor that has a top pressure rating 20 psi higher than you need for your tool (which is usually about 90 psi) and that has a tank of a couple of gallons will work. But the smaller the tank, the shorter time you can operate the tool before the compressor has to kick in. And the lower the CFM at 90, the longer you will have to wait for the tank to come up to pressure again so you can operate the tool at full pressure. If this is for occasional use and you aren't in a hurry, you don't need much of a compressor at all. If you want to operate continuously, then you should get something with a CFM at 90 psi that is higher than your tool's CFM consumption. Keep in mind that impact wrenches don't operate continuously like paint sprayers do.
Good luck.
Vote if you found this helpful.
Al K
Model Number: SS3J5.5GH-WB Manufacturer: Ingersoll Rand Tank Size: 8 Gallons Engine Engine HP: 5.5 HP Engine Type: Honda GX 160 Fuel Tank: .8 Gallon Pump CFM @ 90 PSI: 11.8 Max Pressure: 135 PSI Certification: UL/CSA/ASME Overview Dimensions: 43" x 18" x 26" Product Weight: 175 lbs this can be a reference.
Here are the specs on your compressor: Electric Single Stage Air Compressor, Motor Running Power 5.0 HP, Free Air Flow @ Maximum Pressure 16.1 CFM, Free Air Flow @ 90 psi 18.0 CFM, Maximum Pressure 135 PSI, Phase Single, Voltage Rating 230 Volts, Current Rating 21.5 Amps, Tank Capacity 60 Gallons, Tank Type Vertical, Height 71 Inches, Length 20 Inches, Width 30 Inches, NPT Outlet (F) 1/2 Inch, 60 Hz
Good luck with your new comressor.
Home Use:
Compressed-air power tools can dramatically decrease the amount of time spent on a project. Many homeowners will use smaller, portable units (either hand-carried or wheeled) that move easily from the garage to the house, yard or roof. Common air toolsAir Tools such as brad nailersAir Nailers, reversible drillsAir Drills, and impact wrenchesAir Impact Wrenches require about 0–5 CFM (Cubic feet per minute — units in which air flow is measured). It's important to know if the compressor you purchase will drive the air tool you'll need for your project. For example, smaller air nailersAir Nailers run on 2 to 5 CFM at 70 to 90 PSI, while larger shearsShears, sandersSanders and polishersPolishers require up to 10 or more CFM and 100 to 120 PSI.
Business Use:
Air compressors used for business/professional applications are often classified “industrial grade.” They're packed with features that let you take on more demanding jobs with more horsepower, more CFM, more PSI and more (longer) run times. Though some industrial-grade compressors are portable, many are stationary units with large-capacity, ASME certified air tanks (up to 120 gallons), greater HP, more CFM air volume and faster recovery time to run a wide variety of air tools for as long as you need them to do the job.
Portable air compressors give flexibility to the job both inside and outside the working environment. They're powered by electric, gasoline or diesel engine. A larger portable air compressor often has its own carrying trailer with wheels and handles. You buy a compressor based on its horsepower, pounds per square inch (PSI) and cubic feet per minute (CFM). Choose a portable air compressor to make work quicker and easier. Figure the amount of power you need based on the type of job and air tools used. Know the cubic feet per minute (CFM), such as 5 CFM for small household tools and 10 CFM or more for wrenches or sanders. All air tools have these ratings. Select a gas- or electric-powered engine. Gas gives a higher reliability for frequent use and portability, but consider electric for enclosed areas for its lack of fumes. Pick an air tank based on amount of use time and tools. Large tanks are best for longer use with sanders or grinders and smaller tanks for less time, like wrenches and air hammers. Consider the pump type you need: belt for heavy use or direct-drive for light home use. The quieter belt-drive pump needs periodic oil changes. Buy an inexpensive, small electric portable air compressor for small jobs. These typically operate from a 12-volt power outlet and inflate a 14-inch tire in a few minutes. Get a 150 PSI, 120 volt motor pancake-type air compressor for home use. These light-use models typically carry two air couplers, allowing hook up of two air tools and adequate 25 feet or more air hose. Obtain a larger PSI portable air compressor for bigger jobs, like nailing, with longer continuous use capabilities.
