Motorola Mobility Defy Cell Phone Logo
Posted on Sep 18, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Reset - Motorola Mobility Defy Cell Phone
CARLOS R SOUZA JR
Level 3:
President:
  • Master 1,118 Answers
  • Posted on Sep 22, 2011
CARLOS R SOUZA JR
Master
Level 3:
President:
Answers
1118
Questions
0
Helped
305544
Points
3552
If you want to apply a soft reset, i.e., thus keeping all your data and installed applications, press and hold the power button, until a context menu comes up, and tap 'Power off'. Wait for it to turn off, and press and hold the power button again, until you see the Motorola logo screen. It will come back to life restarted. An alternative way, useful in case your phone is stucked in some odd state, is to remove and re-insert the battery pack.
On the other hand, if you want to hard reset your phone, i.e. restore it to its factory defaults, thus loosing everything you have installed, as well as your personal data, if your phone is operational, go to 'Menu > Settings > Privacy > Factory data reset'. There is a checkbox to optionally clear of your SD card as well. Then, tap 'Reset phone'. On the other hand, if your phone is stuck (i.e. not operational), proceed as if you were soft resetting it, but, when it starts the process, i.e. as soon as you see the Motorola logo, Press and keep holding the volume down (-) key, until you see an exclamation mark. Then, press both the volume down (-) and up (+) keys. The Motorola boot menu screen will come up. Selection of an item is made through either the volume up or down keys, and selection is through the power button. Select 'Recovery -->', then '[Custom Recovery]' and 'wipe data/factory reset'. You will be prompted to select that action again, listed between a lot of 'No's. Afer the wipe is done, select 'reboot system now'.
Hope you are able to sort your problems out soon.
Anyway, please, let me know if Ican assist you any further.
Regards, Carlos
tip
Restarting and Resetting iPad
Restart iPad: Press and hold the Sleep/Wake button until the red slider appears.
If you can't turn off iPad or if the problem continues, you may need to reset iPad. This should be done only if turning iPad off and on doesn't resolve the problem.
if the problems still not resolved Reset iPad settings. From the Home screen choose Settings > General > Reset > Reset All Settings. All your preferences are reset, but your data and media aren't deleted.
Reset all settings: Choose General > Reset, then tap Reset All Settings.
Reset network settings: Choose General > Reset, then tap Reset Network Settings.
Reset the keyboard dictionary: Choose General > Reset, then tap Reset Keyboard Dictionary.
Reset the Home screen layout: Choose General > Reset, then tap Reset Home Screen Layout.
Reset the location warnings: Choose General > Reset, then tap Reset Location Warnings.
7helpful
2answers
Reset
The P300 has 3 kinds of reset mechanisms, 1. Soft Reset: you can keep all DRAM data. Procedure: Push the Reset button 2. Hard Reset/Save SDRAM -- Use hard reset/save SDRAM mode to reset the MobilePro P300 without losing the data in SDRAM. Use this mode if the safe software reset mode doesn't improve system operation. Procedure: Reset Button and Power Buttons at the same time. 3. Hard Reset/ Clear SDRAM: You will lose all data. Use to reset the MobilePro P300 and delete the contents of SDRAM. Use this mode to reset the MobilePro P300 to its factory defaults. This is also referred to as a hard reset/clear SDRAM. **Caution** This procedure will delete all user installed applications and user data. If necessary, back up your data before performing the hard reset. Procedure: Push the Reset, Power, and Record Buttons at the same time
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
