I am looking for self cleaning instructions for a GE oven.
MOD. VJ33VWLW-3
SER.ZH273130
VOLTS 120/208 KW 8.6
120/240 11.4
LR 27
TYPE B45
CAMCO INC.
Made in Canada
I really need to know how to start the self cleaning to clean the oven.
Rule of live by: Each unit must have its own breaker. Cooktop needs 30 amps and a double oven needs 40 amps. Never combine the unit as the amps flow if too high can cause the wires to melt. I hope this helps. Be safe!
Ugh its not fun and takes two people as you have to split the door with several screws and easy hands... take the door off... there's two tabs at the two hinges either slide them forward backwards or some are spring loaded. however get the door off and begin dis assembly preferably on soft surface. pay attention to how things go back together and begin cleaning have fun....
Vivian
the original wiring probably had a red, white, black, and green wire. It is 240 volts. The red is hot, carrying one leg of 120 volts. The black is also hot, carrying 120 volts. The white is neutral, and the green is the ground.
I am against altering this, but you can wire the red and black each to a hot leg, and wire the white and green to the bottom ground. This then introduces a ground wire to your neutral bar in the circuit panel, which is not the best way to do it, but will work.
Best to get an electrician to wire a 4 wire cable to a four prong outlet, and then use a four wire pigtail with a 4 pronged plug.
Lots of people modify it, they ground the green wire to the stove, where the wire originates,and to the box with the outlet in it where it hooks onto the plug if it is metal. Then you have a part ground. And that is assuming you have a cable with wires sticking out to wire to a plug.
Boils down to your decision. If the above isn't the case, get a four pronged outlet and wire the red and black to the top two prongs, the white to the neutral, and the green to the metal box it sits in.
Self cleans generally do a good ****on small messes in 2 -2.5 hours. Larger messes take 3. Leaving the racks in is okay...but they will likely lose their shiny appearance. Manuals are on the GE website.
