Question about Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
I have a Dell Inspiron 9400 laptop with a sony cdrw/dvd cr835e. The drive reads cds without a hitch. It will not read dvds. When I put a dvd into the drive, the drive attempts to read it quite a few times. I can hear it start, then it stops and tries it again. I have no idea what to do. Any help?
  • Sony Master
  • 27,725 Answers
Click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
If this does not fix the problem you might try
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd drive including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on Sep 18, 2011
Cds not playing but Dvd does?
Your optical drive is not working. you need to replace it.
Dec 06, 2017 | Dell Inspiron 9400 Notebook
Can i burn the mini cd's/dvd's in my inspiron 1525?
Yes you can, your Notebook has a Dvd Writer with it, mini or normal dvds/cds will burn well without any problem if the Cd/Dvd Drive has no issues reading/writing Cds/Dvds.
Good luck.
Thanks for using FixYa.
Sep 22, 2010 | Dell Inspiron 1525 Notebook
DVD writer of DELL Vostro 1400?
if it has a DVDRW drive the yes.........if CDRW/DVD then no.....but it can read dvds
Dec 29, 2009 | Dell Vostro 1400 / Inspiron 1420 - 24X...
Same problem: Optiarc won't read a DVD, but CDs are fine
Clean the lens using a cotton buds using a dish washing liquid(dont wet it too much).Then rinse it with tap water and let it dry for a couple of minutes.
Sep 13, 2009 | Sony Optiarc AD-7581A 8x DVD?±RW DL...
Sony NEC OptiArc can't read but can write!!!
Try to play the cd that you have wrote with other machine if it was able to read with other machine then your dvd is faulty.
If it cannot play with other machine, then there is a problem with the software that you use in cd writing or the dvd rom drive. Try to re-install both drivers, then play a cds.
Jun 03, 2009 | Dell Computers & Internet
Would like to upgrade Dell Inspiron 1300 c.d drive
Is your dvd rom drive a RW drive? if not, you need to buy a RW-dvd rom drive to be able to RW dvds or cds.
If you already have a RW DVD Rom drive, you need to have a burning application (ex. nero burning rom). You can check on the internet and download a freeware and install it on your machine.
Jun 01, 2009 | Dell INSPIRON 1300 Celeron 1.4GHZ,256MB...
OS is Windows XP Professional CD drive will not reconize a DVD+R for recording data. The drive is a HL-D-ST CDRW/DVD GCC4244.
A CDRW/DVD is a CD-burner and DVD-ROM combined unit. It is not meant to record DVDs only CDs.
It will not recognise a blank DVD as it is unable to read any file system.
Jun 01, 2009 | Dell Computers & Internet
HL-DT-ST DVDRAM GMA-4082N. Can not write to DVD
The DVD -R +R means that you can read these types of DVDs that have been created elsewhere, it doesn't mean you can write to your DVD under the format of -R or +R. The CD is a CDRW which means you can read and write to CDs.
I don't think that a factory Satellite P100 has the ability to write to either DVD -R or +R, but to only CDs. I have a P200 that has a DVD -R +R/CDRW and it can't write DVDs. These DVDs you put in are for read only. My Toshiba A215 can but it's a DVDRW/CDRW.
Feb 15, 2009 | Toshiba Satellite A135 Notebook
Philips SCB5265 DVD/CDRW drive only reads CDs but not DVDs
Take a can of air and blow it on the laser then try to see if it will read both cd's and dvd's. If it doesn't read one or the other then the dvd-rw would need to be replaced.
Feb 03, 2009 | HP Computers & Internet
DvD drive wont load cds or dvds
Have you tried booting to Windows XP CD (you should have received by Dell initially. If it's ok than you have some filter driver installed in windows that may be causing the issue. If booting from CD does not work either I'd suggest a replacement. Either call Dell or find one on ebay - I can provide link if you like.
Mar 17, 2008 | Dell Inspiron 9400 Notebook
Sony CRX835E CD-RW/DVD-ROM (Combo) Burner Logo
Top Sony Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
