I don't have specific information about the Model 65904 Ecotech solar clock, but here are general steps you can try to set the time and date on a typical clock: 1. Locate the Time Setting Button:
- Look for a button that is labeled "Time Set" or similar. This button is often located on the back or bottom of the clock. 2. Press and Hold the Time Setting Button:
- Press and hold the "Time Set" button until the numbers on the clock display start flashing or blinking. This indicates that you are now in the time-setting mode. 3. Adjust the Time:
- Once the numbers are blinking, use the "+" or "-" buttons to adjust the hours and minutes. Some clocks may have separate buttons for hours and minutes, while others may have a single button that cycles through hours and minutes. 4. Set the Date (if applicable):
- If your clock displays the date, you may need to follow a similar process to set the date. Look for a "Date Set" button and adjust the date using the same method as adjusting the time. 5. Confirm the Settings: - After setting the time and date, press the "Time Set" or a similar button again to confirm your settings. The blinking numbers should stop, indicating that the clock has accepted the new time and date. 6. Check for Other Settings:
- Some clocks may have additional settings, such as a 12/24-hour format or a daylight saving time (DST) adjustment. If applicable, use the appropriate buttons to configure these settings.
If these general steps don't work for your specific clock model, I recommend trying to locate the user manual or contacting the manufacturer directly for assistance. Manufacturers often provide manuals on their websites, or they may be able to assist you with setting the time and date over the phone.
Hold the X time set for 2 sec, then set with % the date to 2000-01-01 . Now set the exact date and press once on te X time set. The date will be saved and with the % key you can change the view of the date to the one you like .Ex 13-06-2011.
