Computers & Internet Logo
Posted on Sep 16, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My laptop will not load up it is charging and the power light is on but there is just a blank scrren please help my i just bought it
Anonymous
Level 2:
Scholar:
  • Expert 83 Answers
  • Posted on Sep 16, 2008
Anonymous
Expert
Level 2:
Scholar:
Answers
83
Questions
0
Helped
39051
Points
216
Can you hear it doing various thinks, ie the hard drive light activity, whilst the screen is blank?
I am thinking that the button the change the screen to the TV or scart socket has bee pressed which means you can choose between the laptop screen and tv screen or an external monitor.
Usually actived unsing combine "function" and "CRT/LCD" buttons (or similar names).
Acer Aspire One NAV50 screen blank
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Only amber light flashing continuously and battery meter gadget shows the full battery but laptop does not come
Buy a new battery, may show as fully charged but does not output to laptop, i had same problem bought new battery fault solved.
2answers
I just bought my smartbook today. When I plugged it in to charge... the red light comes on indicating that it is charging for no longer than a couple of minutes before turning off. Also, when I try to...
I would not attempt any repairs, return this if it is under warranty, there is a fault with the battery, the charger, or the charging/power circuit
Computer doesn't completely boot-up. Little history, needed a new ac adapter and bought a 3rd party/universal adapter (from 2 different vendors) and either adapter worked. Did get power to the computer but...
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced
2answers
My scrren goes black on my laptop with full charge
Have you checked your screensaver settings? Or the Power-Saver Timeout options?
To do this, Right Click on the desktop and go to Properties, then go into the ScreenSaver tab. check your settings here, then go into the Power Management tab and check your Display power-off options.
This should fix you right up! :)
Acer aspire 5520 start up screen
can you go to bios? load default setings in bios, or optimized settings, then try... when something like that happens i usully pull out batery on mother board, than wait about few seconds and pul it back in... bu that is to much work. try above,, and let me know
DS Lite just died but power light still on
before i answer how many times had you charged since you bought the ds
Acer Aspire 5010.. Power on, but Blank screen/ hard drive light also not.
This could be a Power/Switch Problem.
Faulty Hard-Drive.
Solution:- Leave the laptop turned Of And charge the battery to Full Capacity. ( usually between 4-16 Hours ) depending on capacity.
This will also fully charge the CMOS ( memory battery )
then boot the laptop up, and see if this solves your problem.
If not i,d suggest running a scandisk or hard-drive diagnostic program, to ensure that you have no Viruses-bad sectors on the hard-drive.
If you need further assistance please don,t hesitate to ask for more help and advice.
Mike @ Compurepair.
2answers
Dell pc not working
Try to clear first cmos settings and if it wont work soo u have a problem with VGA OR MOTHERBORARD
Grand Canyon Tech
Grand Canyon Tech
