Samsung SyncMaster 204B 20.1" LCD Monitor Logo
Posted on Sep 17, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
ONLY BLINKING POWER BUTTON ON THE DMONITOR. NOTHING ELSE IS THERE.
Buddy Mcsparrin
Level 3:
  • Samsung Master 1,684 Answers
  • Posted on Sep 19, 2011
Buddy Mcsparrin
Samsung Master
Level 3:
Answers
1684
Questions
Helped
1011257
Points
4641
This is a common problem with the Samsung 204B units that have been in service for a few years. Parts called capacitors in the power supply start failing and causing the board to not start correctly. The blinking power button is just the power supply restarting over and over. The monitor is easily repairable, you just need to replace the 5 capacitors that have failed. Here is a link to a page that shows how to open the monitor, get to the power supply board and what to replace.
http://www.ccl-la.com/blog/index.php/samsung-204b-lcd-monitor-repair/
I hope this helps, if so please rate my solution.
BuddyMc
Picture not adjusting to full screen an dmonitor buttons Exit, brightness, contrast and Menu are not working also. Checked all buttons contacts are ok.I tried to search for vertical and horizontal variable...
You will need to reset the resolution to fill the screen. That is done through Windows.
If the actual menu buttons on the screen are not working, you probably need a new monitor.
var fctb_tool=null; function FCTB_Init_5ddec69ff7a64d918e9c62baf4d86075(t) { fctb_tool=t; start(fctb_tool); } var fctb_tool=null; function FCTB_Init_4b77af1c80d64567931291644b9994c7(t) { fctb_tool=t; start(fctb_tool); }
My dell monitor wont display my pc image
Make sure you use the correct selection for your input (the leftmost silver button) to cycle through DVI-D, D-Sub, S-Video, and composite.If you are using this as a second monitor from your laptop, you have to activate the secon dmonitor using your keyboard or the operating system.
7helpful
Tv wont turn on. power button blinks
if your tv is blinking you are still okay but your set needs service, maybe some board or circut is defective. this happens with panasonics, they have a blink timer. they blink a certain number of times. this blinking feature is called safety mode, you find the part that is fualty according to the number of blinks, you can find out what fualty part is cuasing the tv not to go on by downloading a service manual in pdf format or finding the blink codes, how many times does it blink count it carefully i may have a manual here and maybe can tell you what to replace.
I have a panasonic 47wx42f. the power button blinks and no pic
how many times does it blink between pauses as it may be a error code
NOTHING HAPPENS!!!!!
power supply probel, need to take to service
The printer apear to be dead!
Buttons and lights on the printer Two buttons and three lights are located on the front of an HP Deskjet printer.
  • The lights tell when the printer is working or when it needs attention.
  • The buttons help control the printer.
Buttons and lights Purpose c00123886.jpg POWER button and light Push the POWER button to turn the printer off and on. When lit, the light shows that the printer is turned on. c00123889.jpg RESUME button and light The light blinks when there is a problem with paper. When the problem is corrected, press the button. c00123892.jpg Print cartridge light The light blinks when there is a problem with a print cartridge. When the problem is corrected and the top cover is closed, the light will stop blinking. Troubleshooting blinking printer lights Blinking lights Reason c00123895.jpg
All lights are off. The printer is off (asleep).
Press the POWER buttonc00123886.jpg to turn the printer on.
The printer should turn on automatically when a print job is sent to it. c00123898.jpg
The POWER (top) light is on. The printer is idle.
The POWER (top) light is blinking. The printer is busy printing.
Allow enough time to print. When a document has many fonts or graphics or uses complex color such as a color photo, it takes longer to begin printing. c00123902.jpg
The PRINT CARTRIDGE (bottom) light is blinking. Possible causes:
  • The front cover is open. Make sure the front cover is completely closed.
  • The print cartridge is missing. Make sure the print cartridge has been installed correctly.
  • The print cartridge is broken or incompatible. Lift the front cover, and wait for the print-cartridge cradle to slide out. Check the part numbers on the print cartridge:
Black: 51645A
Color: C1823D,
If the print cartridges are compatible and correctly installed, they may be defective. Try replacing the print cartridges.
If none of the above suggestions fix the problem, and, if the error message still occurs, it may be a hardware failure. Call the HP Customer Support Center.
The power button on my Philips DVD player blinks.
The Front PCB might be damaged. Check the front PCB
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
