A common problem is that the switch contacts on the headphone jack that send the audio to the speaker when headphones are unplugged go bad. Some of these are so low quality that after a few times of inserting a plug the contacts no longer make. If you can access the jack, you might find a jack similar to: http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=RA49B12B-ND
What happens is the spring tension on the tabs over the top of this that contact the leads to the speaker lose tension and no longer press hard enough on the contacts to make contact. Try to open your unit and see if it has this kind of jack... Frankly, these jacks are JUNK and a chronic problem.
