Hello, jduffy
I was trying to help
you out here. I was going back to some customers that asked questions
in the past and it appeared that no one answered them, so I thought I
would take some of my personal time to see if I can help. Even though
this site may not have your exact model or brand, This link will help
you tons. Here is a link
to about everything you want to know about your dishwasher, from repair
to trouble shooting it,pictures, video's. Just scroll around and you
will see tons of information to almost any question you might have on
your dishwasher. If you go to this link and click around, I am sure you
will find out so much about your dishwasher, you will know more that the
company that made it. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time
to rate my help and some kind words written would be appreciated for my
free help , I would appreciate it. Here is also my direct link to my own
pages of other areas of my expertise for other problems you might have
in Automotive,Appliance, and Electronics. Drop In anytime for my help.
Thanks,Mike
http://beta.fixya.com/users/mc1bean
I just had this same problem, and I think I figured it out. There was water on the bottom from the last cycle, so I pressed HEAVY and DELICATE at the same time for 3 seconds (you'll see it printed on the control panel), and the unit drained. I was then able to start the new cycle normally without the error. Hope that helps!
draining is not the problem, I think there is an issue with the computer panel, I had two repairmen come in, the first was a nightmare he actually said it could cost $500.00-$1,000.00 to fix and it depended what it was worth to me, I showed him the door, the seocnd guy brought his service repair manual and reset the computer, I don't think you can reset by turning off the power as the computer needs to reset by pressing the right codes, this is what I need, otherwise I will call Larry again and ask him to come reset the computer, I'm trying to save the service call fee. If there is a power surge the computer will mess up and needs resetting. I think next time there is extreme weather I will turn the breaker off and hopefully that will prevent the computer issuing errors.
Draining is not the problem, I think there is an issue with the computer panel, I had two repairmen come in, the first was a nightmare he actually said it could cost $500.00-$1,000.00 to fix and it depended what it was worth to me, I showed him the door, the seocnd guy brought his service repair manual and reset the computer, I don't think you can reset by turning off the power as the computer needs to reset by pressing the right codes, this is what I need, otherwise I will call Larry again and ask him to come reset the computer, I'm trying to save the service call fee. If there is a power surge the computer will mess up and needs resetting. I think next time there is extreme weather I will turn the breaker off and hopefully that will prevent the computer issuing errors.
First 3
programme
indicators
flashing
E5 Water tap not turned on.
Insufficient water supply pressure.
Water supply hose is crimped or
bent.
Drain hose is too low.
Ensure the water is connected
and turned on.
Check household water pressure.
Check hose and straighten if
needed.
Ensure that drain hose is
connected in accordance with the
'Installation instructions'.
For details refer user guide.
Thanks for the advice. Actually found out my dishwasher was under warranty still and repairman came out. I was not home at he time, but the wife said it had to do with sensor being dirty or clogged. Anyway he cleaned it and it works great.
