Maytag Neptune MDE5500AY Electric Dryer Logo
Posted on Sep 16, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Maytag dryer fault code 8.8. what does this mean
  • 2 more comments
  • kcadman Oct 17, 2008
    Code 8.8 displays on the control panel at various times. The dryer becomes non-functional and 'frozen' but eventually will correct itself after hour or so. Any suggestions?
  • fgsi Oct 20, 2008
    Exact same problem. Can not reset!! Does not automatically reset even after an hour.
  • genelathrop Oct 26, 2008
    display shows 8.8 sometimes resets in an hour one time took a day.
  • rradintz Nov 18, 2008
    8.8. shows in display, I have unplugged several times, however it is still present
Anonymous
Level 3:
  • Master 725 Answers
  • Posted on Oct 26, 2008
Anonymous
Master
Level 3:
Answers
725
Questions
Helped
406775
Points
1785
88 is not a error code on the tech sheet..all error code should have an F-XX I think your control must be showing a bad circurt in the control... you need to replace control... hope it helps
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 06, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2991
Points
This has been happening to our dryer of the same model for 2 years.
we un-plug, plug, un-plug, plug, un-plug, plug over and over until we get the display back.
sometimes it'll go rght back to 8.8. other times it will work for a couple of minutes and freak out and stop again.
we've found if we can get the display back to normal switching to Timed Dry instead of Sensor Dry will sometimes work better, but as of late it working less and less.
Humidity seems to play a part. Today is horridly rainy and humid and I'm ready to smash it to pieces.
its annoying, not a show stopper. Typically we can get it to work in 1-4 minutes.
Once its hot its not a problem. If I can get it to run through a single load i can keep loading and running it as long as its hot.
Once it cools down, it can start all over again.
Maytag dryer 3000 fault code f22
Replace the door latch. Fault code F22 is for the door latch.
What does the fault code F04 mean on my Maytag MTD09WH?
Control board/ key pad is bad / stuck, replace
I have a Maytag bravos dryer, with a fault code of FE4. What does this mean?
A lot of them dryers have a pulley failure on the blower
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
What does fault code 99 indicate?
What? 2days? Call the installer! or seller. Could be a gas supply safety problem!
2helpful
I have a Maytag Neptune electric dryer model # MDE9700AYW and I have a fault code " FE " & the dyer doesn't dry the clothes. What is my problem
Maytag Dryer and FE code means power source "Frequency Error".
Invalid power... you will need a electrican to come out the power is not wired up right.
I would replace the wall receptacle before buying any dryer parts
Hope this helps (remember to rate and comment this answer).
I have a Maytag Neptune clothes dryer and have had it for years with no problem, love my dryer!!! However, this morning I tried to dry some towels and a code 8.8. displays on the display screen.. Please...
There is a technical sheet inside your dryer's cabinet. You can usually find it by accessing the rear of your dryer. All the fault codes should be explained in this paperwork.
3helpful
Maytag 3000 series dryer fault code f22. what does it mean? dryer is just over a year old so i think i'm outside warranty.
F22 is an exhaust blockage. Machine shuts off to prevent overheating and causing a fire. Check the exhaust in the back for blockage. Also clean lint screen before each load to decrease the chance of exhaust blockage
Dryer is spinning, but clothes are not drying
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning open circuit)
4 Modern tumble dryers also have sensors and pcb's (Printed circuit boards) these have programs that can fail and circuitry although most should produce an error code showing you were the fault is.
5 Faulty connections and burned wires may also be the fault.
We have a full video library on appliance repair video’s
You-Tube video "oYErKqR3LsY" placeholder (do not delete)
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
