Nothing, nada, happens when I push the power button. Tried the stop-maintenance button combo also. The fuse in the power supply is good. Power gets to the power supply but who knows from there
You may have a problem with the switch panel board. If you disassemble it, you may be able to test the panel by shorting the two connectors to the power button. On the other hand it could be the power supply that is dead on the output side. Both are problems that do occur with R3** series but not that common.
