Microsoft Windows Media Player Logo
Posted on Sep 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to fix windows media player error code C00D1199? What program or repair tool to use to fix this? Thank you.
Nanny
Level 3:
Genius:
  • Microsoft Master 2,351 Answers
  • Posted on Aug 17, 2019
Nanny
Microsoft Master
Level 3:
Genius:
Answers
2351
Questions
0
Helped
989332
Points
7262
Below are the several causes for Windows Media Player c00d1199 windows 7
  • * Incomplete installation of Windows Media Player software
  • * Unsupported files in Windows Media Player was played.
  • * Registry errors
  • * The required codecs are not prepared.
  • * The damaged output devices or sound controller
  • * Virus infection has corrupted Windows Media Player
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 11 Answers
  • Posted on Oct 09, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
11
Questions
0
Helped
839
Points
12
If you work on win XP you can download K-lite codec
but if you work on win 7 you can download win7 codec
2answers
How To Fix Error Code 0xc0000001 On Windows 10 ?
When we will install windows 10 then error code 0*c0000001 will keep popping.
The causes of error code may be
1. Damaged SAM file
2.
Damaged system files
3.
File system integrity compromised
4.
Damaged RAM
Here is method that will help to fix error code
Use Media Creation Tool to Perform Automatic Repair
Automatic Repair is a Windows feature that allows you to fix certain system problems preventing you from installing or starting Windows. It works by scanning your computer system for any potential problem and tries to fix it.
Step 1: Download the Media Creation Tool
Step 2: Boot your computer using the Windows 10 DVD, or the System Repair disc. When you're asked to press any key to boot, just press any key on your keyboard.
Step 3: Choose the right time and the keyboard type.
Step 4: Click Repair your computer. You'll see this at the lower left corner on your screen.
Step 5: Choose Troubleshoot from Choose an option screen
Step 6: Click advanced options
Step 7: Choose automatic repair
3answers
My windowsmediaplayer does not work?
Is it only with certain files? Or does it not even start?
If its certain files i suggest you use VLC media plaer for example.
http://sourceforge.net/projects/vlc/files/1.1.10/win32/vlc-1.1.10-win32.exe/download
3answers
I can play cds in windows media player but i cannot burn to cd it comes up with error message C00D119F , how can i repair this
You need to be sure that your cd drive is also a cd burner. If it is then the problem might be fixed by any of the following: 1. Clean your disk that you are writing to or try a different one. 2. Use a cleaning CD to clean your drive. 3. Close any other programs that might be using your drive, song, or windows media player. 4. Restart Windows Media Player. 5. Restart your computer. 6. Try a different brand of cd to write to. 7. Choose a slower writing speed. Please rate my post if it was helpful! Best of luck to you.
None of my songs will play on my Zune. When I connected it to my pc, I get the error code C00D1197 (C00D1329).
Since the error C00D1197 Windows Media Player is usually generated by the program itself, sometimes, it is suggested to restore the Windows Media Player.
However, you can try some other ways for this issue:
How to Fix Error C00D1197 on Windows Media Player
3helpful
2answers
How do i fix error code C00D11B1 Media player 11 ?
Recognizing and Fixing Media Player Error Code c00d11b1
For the majority of Windows Media Player users who encounter the Media Player Error code c00d11b1 message, the problem only begins after they upgraded to 11. In other words, media player versions 9 and 10 worked perfectly well for them.
So, one option is to 'roll back' the player to a previous model that did not encounter any such problems.
To do this, initially go to Start, then Control Panel, and Add/Remove Programs. Next, click on the Windows Media Player 11 icon and click Uninstall.
It will ask if this is really the option you want to take. Confirm that it is, and then be patient as it may take several minutes for the operation to be completed. During this time, it may appear as if your PC has switched itself off, but it has simply deactivated all unnecessary extraneous computer operations, in order to retain memory and processing power for the job in hand.
Next, according to Microsoft, when this particular error code is encountered when trying to stream online video or audio, it most commonly indicates that the proxy settings for Windows Media Player are incorrectly configured.
This can be checked from the Tools menu within Media Player itself, after whch you need to click on Options. Then you must click the Network tab and in the Streaming proxy settings area, you need to verify your settings. If you're not sure what the correct settings are, first, click on Configure, and then in the Configure Protocol dialog box, select Autodetect proxy settings.
In some cases, you can also apparently encounter this problem if Media Player tries to receive an online stream by using the User Datagram Protocol (UDP), but for some reason, it cannot do so.
You may be able to fix this particular error by turning off this UDP option in the Player.
If these solutions are not effective, your problem may be something as simple as Media Player trying to access the wrong audio or video device on your machine.
Open Tools, select Options, and then select Devices. When this comes up, make sure that the correct audio for your PC is checked, and this could very well make your problem disappear.
If none of these operations is effective, then you may well need to check the underlying registry of your Windows operating system for defects and errors that may be causing Media Player to malfunction.
Almost inevitably you will find errors and defects in your registry whenever you run a thorough scan, and whilst it may not necessarily be possible to isolate a specific problem that is causing Media Player to malfunction, the cumulative effect could be the root cause of your difficulties.
If, therefore, you already have software installed on your machine that can scan and fix your registry for you, then you should use it.
If not, you can still avail yourself of a free online registry scan using proprietary software such as SpeedyPC. Whilst you will not be able to repair your registry errors without downloading and installing the full version of the software, nevertheless, the scan will indicate the extent of the problems that you have, and these problems may be what is causing you difficulties with Media Player.
Or download this software after downloading, install this software and try vlc media player. This will install (codec) compressor/decompressor for audio and video more supported multimedia.
14helpful
4answers
Youtube video not play
This is the mismatch of video format,
you can download a video converter, this kind software
can convert all kinds of video files to which you want.
as to youtube video files,you can download a
aneesoft youtube video converter.
2answers
My windows player is not work
I have had a simillar problem.
What to do:
1) go to control panel
2) clic on "add or remove programs"
3) uninstall windows media player and all of the players updates (if any)
4) go to microsoft's site for windows media player
www.microsoft.com/windows/windowsmedia/
5) select the latest version that applies to your operating system
6) download it
7) install it
that should fix the problem
hope this helps
1helpful
3answers
PMC Firmware Corrupted, Try to install new firmware 1.03, can't
remove the device then runn the program and when it asks you to connect the device then connect it if that doesnt work please post an aditional comment and i'll see if i can help you out more :)
1helpful
2answers
WMP error message-C00D11B1
Can you try this:
  • Start-> Control Panel->Hardware and Sound
  • Sound / Manage Audio Devices
  • Highlight your audio device
  • Properties
  • Advanced
  • In the Exclusive Media section, UNCHECK the box "Allow applications to take exclusive control of this device."
  • Apply
Hope this helps.
Thanks.
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
