Computers & Internet Logo
Posted on Sep 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can i install windows any other version or any other os in my wespro n721 running on VIA 8650 CPU
A Miller
Level 3:
  • Master 8,404 Answers
  • Posted on Sep 16, 2011
A Miller
Master
Level 3:
Answers
8404
Questions
Helped
2052881
Points
24677
Check the Windows Hardware Compatibility List ... google it ...
Linix might be an option ... check their hardware requirements ...
You could ask Wespro directly ...
These are things I woujld do to arrive at the correct answer.
What came on your comuter and what happened to it???
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 20, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
467
Points
My net book softwere all fomat new softwere install
Anonymous
Level 1:
  • Posted on Jul 27, 2012
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
467
Points
0
I WANT TO FORMAT AND INSTALL WIN XP3 0R 2 BUT HOW DO I GO IN BIOS TO SELECT DVD/RW PLS HELP ME THANK YOU
Datacard sp 75 plus printer not detected by cpu
Have to ask - did you download and install the printer driver programs prior to connecting the printer for the first time via USB? If not, disconnect the printer; go to the Datacard website to obtain the latest driver version; install while logged in with a Windows Admin ID AND with "Run as Administrator" option, then only power-on and connect the printer when prompted to do so. Note there are driver versions for both 32-bit and 64-bit versions of Windows - through Win10 - so make sure you pick the one to match your installed OS.
You can/should also try on an alternate PC as a test. It could be you have a bad USB port on the printer (easy to break by bumping into the connector on the back of the printer while it is plugged in).
Safe-Card ID Services
Charlotte, NC USA
https://www.safecardid.com
Wespro n721
If its Android, you can perform hard reset.
If it's based on Windows CE, you will need a bootable USB drive to start it with.
1helpful
In my wespro NS721A laptop mini there is no os installed.i want to install windows ce
I want to install windows ce in wespro NS721A with the help of SD card
1helpful
Cannot install MGI PhotoSuite4 on a computer running Windows 7 OS
The PhotoSuite 4 program is very old and won't work under Windows 7. http://sonic.net/mnitepub/pccafe/reviews/photosuite4/photosuite4.html says that the version 4 Platinum edition ran under Win95-Win2000 versions of the Windows OS. Thus even the compatibility mode probably won't help under Windows 7 32-bit. You can try it though by right clicking on the installer and then selecting Properties. In the Compatibility Mode tab, select Always Run this program in the compatibility mode and an older version of Windows. Then right click again and choose Run as Administrator. (You may have to do this again on the program itself.) Since Win7 64-bit requires signed drivers or programs, it is not as likely to work. (Check your version of Windows 7 by clicking Start > Control Panel > System and Security > System. If the title of your OS ends with x64, you have the 64-bit OS. Otherwise, you have the 32-bit OS.)
If you have Windows 7 Pro or Ultimate (or upgrade to one of those versions), you can run a virtual version of XP for free. Download and install Microsoft's Virtual PC and then XP mode (in order). This works best if your CPU supports virtualization and you enable the feature in your computer's BIOS. (There are work-arounds for computers without virtualization. See the MS support pages.) Install your PhotoSuite inside the virtual XP program in that case.This old software may run in that case. (However, I've had some Win2K software that ran under XP with the compatibility mode but didn't run under the virtual XP. Note: virtual computers do have some additional limitations. They do not talk to the host hard drive and other hardware directly. (You can install a printer on the host machine or the virtual machine but not both.) You'll need to save files on external media (flash drive, optical disc or other hard drive) to transfer them between the machines).
Another option is to run an older version of Windows on another computer, as a dual boot computer or with Virtual PC (or another virtual computer package - VMWare or Parallels). In that case, you need a licensed version of the older Windows OS. Again install the program while running the older OS.
The final option is to upgrade to a Windows 7 compatible Photo editor and organizer. (Even the Microsoft Windows Live Photo Gallery has some of the features of Photosuite SE.)
I hope this helps.
10helpful
2answers
How to install xp in wespro ns722
You will need to format a USB stick to boot a windows XP install disk. (Check the link at the end of this post for additional info)
From there, boot your computer and at the very first screen it will tell you you can press a keyboard key to enter SETUP. (usually either DEL or F2). Press this right as it starts to boot. This will open your boot manager. Find your boot device priority list and set USB above your hard drive. This will allow your computer to the detect the drive and begin installing XP to your computer.
For more info:
http://komku.blogspot.com/2008/11/install-windows-xp-using-usb-flash-disk.html
Hi, recently purchased new pc asrock m/b amd phenom II 555 cpu etc installed XP run ok shutdown that night switched on next day say midday and no signal on monitor, subsequently have installed XP and Win 7...
when you install windows 7 dont download the drivers from there website unless you can find the 32bit version. if not. windows 7 will find the drivers right for you that will solve the problem. i have seen this on a few asrock m/b issues with win 7
this is your solution if this doesnt work give me some more details im on all night you may contact me via aim littleiceylilb for more trouble shooting help
72helpful
7answers
Sir, I am having wespro n720 netbook. It having Windows CE 6.0 OS. I am not comfortable with that. So I want to load Windows XP. Is it possible ? Please give me your Suggestions.
Sir iam using wespro n720 smart book. This asking usb drive name and how to connect mobile through internet give me a usb driver name. Plz help me
Windows vista 2006 version wont start in a aspire 3210
does your system match the system requirments of windows vista 2006 version, if not then it will not start, o.s today require high computer specs in order for it run properly, you should know the specification of your system before you had win vista installed does your system have requirments to run win vista, if not better revert back to the o.s. where it runs smoothly or have it upgraded to accomodate windows vista
Grand Canyon Tech
Grand Canyon Tech
