SOURCE: Value Stack Flue Sensor
3.5 to 4K If you want to bypass the sensor just jump a 1 dollar resistor in between the two wires. If you want to put another sensor just use a standard gas heater flute sensor(2dollars) and put in line with the resistor
SOURCE: Sta-rite pool heater shuts down as soon as the
Between the two water pipes on the left side of the manifold is a two inch plug. When you take this plug out the thermal regulator assembly will come with it.It consists of "O" rings, a spring and what looks like a thermostat in a car. This is the probal bad part although it could be the spring also. You can get these parts seperatly or in a kit. If this is an older heater the kit is the way to go so you get all the nessary "O" rings and you will be covered on everything you need.
SOURCE: how much clearance is required for enclosure of
That can all be found in the owner's manual here.
John
First, make sure your unit has good, tight and solid ground from panel, to timer, to heater. Then make sure you have your pump running on high if you have a two speed or variable pump motor. Then try it. If that doesn't work...change out the water pressure switch. It'll cost you 40.00. Done deal. Next....
