could you tell us how to fix that? its not a solution to point out the problemcould you tell us how to fix that? its not a solution to point out the problem
could you pleas tell use how to fix that, pointing out the problem isn't a solutioncould you pleas tell use how to fix that, pointing out the problem isn't a solution
You can't post conmments that contain an email address.
The speed of the sound coming out of the chip is too fast. Perhaps it was designed in Europe where the frequency of their electrical network is 50 Hz It is 60 Hz here and may speed it up unless they designed a way to calibrate it. Chances are it was not thought out that well at the design stage.
Chipmunk
Sounds From Computer Speakers My
wife had an interesting issue over the weekend. Anything she played on
her computer came through the speakers sounding like chipmunks. You've
heard the Alvin and the Chipmunks albums, that's what it sounded like.
It didnt matter if it was a Windows sound (wav file), and MP3, a WMV,
or any other multimedia. Everything sounded like a chipmunk was playing
it. The sounds were played too fast and too high pitched.
Her
computer is an Acer with a Realtek sound card built into the
motherboard. It has the Realtek HD Audio Manager built into it and I
thought at first that something had changed with the audio settings.
However, after examining the audio utility and choosing to reset the
environment back to its defaults the chipmunk sound was still present.
he
Realtek Manager also has an option for Karaoke Mode, which basically
removes the voice track when playing a song. Changing this feature had
no effect on the system.
Uninstalling and Reinstalling the
Sound Card
The
only way I found to truly fix the issue was to uninstall and reinstall
the Sound Card. Follow the directions below to accomplish this.
1) Open Device Manager by Right-clicking on My Computer and choosing
Properties. Then click on Device Manager
2)
Under the Sound, Video, and Game Controllers section, Right-click on
Realtek High Definition Audio and then click on Uninstall.
3) Close the Device Manager and Reboot your computer
4)
After the computer reboots, allow it to automatically find the Realtek
audio device on its own and reinstall the drivers. You may be required
to reboot the computer a second time after the drivers for the sound
card load.
5) Test the sound card by playing an MP3, WAV, WMA, or other sound or
by watching a video online.
The
problem should be fixed. If for some reason, you are still experiencing
a chipmunk-like sound coming from your speakers, visit the sound card
manufacturers website and download and install new drivers for the
sound card.
you will need to locate the volume button at the bottom right hand off desktop and change the volume settings, i cant say exactly witch setting to change because i don't know what software you are using. But something in those settings is causing this.
Any further questions please ask.
Correct? vote would be usefull.#
Thanks.
You can try adjusting the pitch's gain, which is located on the pitch control circuit board. Only problem is that you'll have to take apart your turntable in order to get to that section (its on the bottom).
If that does not work, your pitch might be bad, or one of the main circuit drive IC's might be bad.
Re-install your sound driver, and see if that solves your problem,,
Let me know if that worked,
You can remove your sound driver from the device manager , by right clicking on my computer, select Properties, and then under the harware tab you'll find device manager
Go to your sound card settings under start settings control panel, select the real tek audio then in there there should be settings on how your sound comes out of your computer make sure that it is not set on some funky audio morphing setting. Someone must have played some pranks on you but yes its total fixable with a couple strokes of the mouse. ruldss2008
I had the same problem and found this post on another site. It worked like a charm.
Dude Check It. i just fixed mine..go to the main menu and go to sound effects you will then find a area that says karaoke put that on #0 and that should fix your problem..
This post has been edited by VoLt: Oct 8 2008, 11:51 AM
