Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer Logo
Posted on Jul 27, 2017
Bosch Nexxt 500 washer which is 4 years old, continously adding machine wash times to cycle. At start of cycle with options selected it starts with 56 minutes run time. Mid-cycle the timer has 1 hr 26 mins to complete, so on, so on. Wife complained that 1 cycle start at 56 mins and eventually ended after approximately 3 hrs run time. This doesn't happen with every washing but seems to occur more and more.
5 Related Answers
David Shaub
  • 2994 Answers
  • Posted on Mar 18, 2009
SOURCE: takes forever to do the laundry
If it is taking forever to fill, take the water hoses off the supply and check for clogged filters. Also, if you have low water pressure in your house, or old clogged pipes, your water is running slow.
jimorris77
  • 411 Answers
  • Posted on Nov 29, 2009
SOURCE: bosch nexxt series 500. error eo4
I am not a repair professional. I am just a 78 year old
man who has been making his own repairs for about
50 years. Therefore the washer or dryer ID doesn't
mean much to me. I came to fixya looking for a
schematic for an really old AM/FM radio and
discovered that more than 4,700 people were asking
for help with a washer repair. I recently had a washer
repair of my own and found an excellent video which
showed me how to take my machine apart. This
video made it possible for me to do my own repair. I
was so impressed with the video that when I saw all
these people needing help, I wanted to tell them
about it. If you have a top loader (washer) of the
direct drive type, this video might be a Godsend for
you. If you look at the back of your washer and the
panel is solid (no small inspection plate to remove)
chances are you have a direct drive and this video
is just what you need. You can see this video at
www.acmehowto.com You will probably need
more help in determining what the problem is and
how to fix it. If your repair problem is a washer or
dryer I suggest you go to www.applianceaid.com
where they have very good trouble shooting and
repair information on most washers and dryers.
I think you'll find what you need there. Don't worry
about the timer, they hardly ever go bad. Good
luck with it. If I have helped you, please rate my
advice on fixya.
Anonymous
  • 1998 Answers
  • Posted on May 01, 2010
SOURCE: noisy pump in bosch nexxt 500 washer
no its usually not that loud at all contact bosh direct to have them send you a new one or call them if its still warrantied
Anonymous
  • 523 Answers
  • Posted on Jun 23, 2010
SOURCE: It is a Bosch WFF2000. The programme stopped mid
circle at bottom right take it off there is a filter there remove it and look of obstructions.WATER WILL POURE OUT!
Anonymous
  • 11896 Answers
  • Posted on Oct 07, 2010
SOURCE: Our Bosch Nexxt 500 series
the timer will need to be replaced. Daysappliance and partselect.com both have parts, manuals, diagrms, and more.
How do i get the beep at the end of the cycle to turn off
To disable the end of cycle beep on the Nexxt washer, select a program and press two of the option buttons (e.g. Stain Removal and Allergy Rinse) and hold until you hear a short beep.
My 2.5 year old Bosch Nexxtg 500 WFMC3301/UC washing machine fills then drains. Does not complete wash cycle. If I leave off for a couple of days it will fill then drum turns for awhile, but will not...
sounds like heater fault this will terminate program if no heat detected after a short time, hard water will make it worse unless you use a water softening agent.2.5 years for this is not unusual.
2helpful
3answers
Bosch Nexxt 500 Series Front Loading Washer
The only way is to disonnect the device from the controller board.
7helpful
4answers
Bosch Nexxt 800 washer won't drain clothes fully
There is not a Spin Only Cycle BUT there is a REFRESH cycle that will take about 10 minutes.
Sometimes when the load is unbalanced and the machine can not balance the load by itself, the clothes will remain soaked. To avoid this, make sure you always have a balance of small and large things and when loading your machine, do not shove the items in so they ball up.
Bosch Nexxt 500 Series Washer Will Not Add Water
during a normal wash cycle the washer stopped and gave an e;4 error code
Acoustic signal
select a cycle. hold down two option buttonsat same time until you hear ashort signal this disable it. (bleach& rinse pluse) to activate do same
1helpful
2answers
Detergent dispenser
As far as I am aware, there IS NO dispenser for bleach, you have to put bleach in drum before adding clothes and starting cycle. The far right compartment is only for "pre-wash" cycles, and if no pre-wash is selected, water will run through ALL compartments at the rinse stage..... Oshie
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
