Technics SL-1200MK2 Turntable Logo
Posted on Sep 15, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Phono Preamp buzz
I'm running my sl1200mk2 through an audio technica ATPE03 phono preamp into bose powered computer speakers through anRCA (red/white) cable...
it's emitting a huge buzz, even when not on, but just connected... the wires seem fine, any suggestions?
Anonymous
Level 2:
  • Expert 515 Answers
  • Posted on Oct 08, 2008
Anonymous
Expert
Level 2:
Answers
515
Questions
0
Helped
292973
Points
647
Ditto. Double check the ground cable. If it is connected, then try a different set of RCA cables. Also check the connections on your headshell/cartridge. Make sure all 4 wires are properly secure.
- OPTiC
DJ PRO LAB
DJ PRO AUDIO
A
Anonymous
Don't forget to ground the ground cable from the turntable.
Have an RX_V371 that I use for cd's. Just bought Audio Technica turntable with phono preamp, thought I had it set up but almost no sound coming through?
There is no phono input on unit. If you wish to use turntable you willl need to buy a quality preamp, and appropriate cables.
1helpful
2answers
We are trying to connect our Sony PS-LX300USB turntable to our Denon amplifier, using the supplied USB cable. When we play the record, no sound is coming through the amplifier speakers?
If you want to use the USB cable it should be connected to a computer not a audio receiver. If you want to connect to a Denon amplifier then you should use the left and right audio cables. Check if it has phono level out or line level out. If it's phono level out, it needs to either go through a phono preamp or plug into the phono input on the back of your receiver. If it's line level out, you can plug it into any of the other inputs and it will work.
The USB cable is mainly for recording your records to digital. But if you want to run the audio through the USB cable and listen to it in real time then here's a link that shows you how to do it. It's a different brand turntable but the process is the same.
https://blog.audio-technica.com/audio-solutions-question-week-can-listen-usb-turntable-pc-speakers/
1helpful
2answers
Marantz nr1402 how to connect turntable
Connect turntable out to phono preamp In
Conect Phono preamp out to your Marantz NR1402 vacant analog input.
On your TV , if audio out is available connect it also on the Marantz
vacant analog input 2
The sound is really low if i press the aux tape cd phono or vcr the sound is there but really low
Instructions:
Evaluate your current receiver. Take a look at the back-panel connections to make sure you don't have a phono input. In most cases, the phono input will be clearly marked. If the connections are not marked, look for a set of RCA-style inputs with a grounding screw next to them; this is a phono input. If there isn't a phono input on your receiver, see if you have an open set of RCA inputs. If they are all occupied by other equipment, you can disconnect one piece of equipment, buy an A/V switcher or get a new receiver--preferably one with a phono input.
2 Purchase a phono preamp. The voltage output of a turntable is much lower than those of other peripheral devices, including CD players, tape decks and game systems. Although the inputs look the same, connecting a turntable to a standard RCA audio input will result in very faint sound output, if you hear anything at all. The output of your turntable must be amplified to a level of about 150 millivolts (mVs) before it reaches the receiver, so a turntable "pre-amplifier" or phono preamp is necessary.
3. Purchase patch cables. You'll need a set to run from the preamp to your receiver. Measure how long your cables need to be, and purchase accordingly. Resist the temptation to "go cheap," because better-quality cables will provide better sound.
4. Connect the preamp into the system. First plug the preamp into an AC power outlet. Most models have a small AC-to-DC adapter built into the plug. Then connect the cables from the turntable to the preamp, and connect your new patch cables from the preamp to the receiver.
5. Adjust the gain of the phono preamp. Most models have a gain control for fine-tuning. Follow the instructions provided by the manufacturer and adjust your system accordingly.
F150 Parts.
How do i attatch preamp to marantz sr9200 for phono
If you are talking about a phono preamp, take the output rca cables from the turntable, "red and white" plug it into the preamp input, "labled" next take a red and white cable wire male ends, "3 to 6" feet long, and plug the one end in the output of the preamp, "labled" and finally plug the remainder into the AUX input of the Marantz receiver matching the colour codes so the left and right channels don't get mixed up, you now should be good to go.
1helpful
Connected to turn table. having sound problem. At 99, sound hardly audible.
The bose as most all in one systems do not have an inbuilt phono stage. Phono especially MM type have a very low signal and an eq curve that gets altered in the phono stage. Without a phono stage (known as a phon pre amp) you will not get much fun from your turntable. To connect : turntable out - into phono preamp - phono pre amp out into bose line in/aux in
1helpful
Pioneer a858 amp no sound from phono stage, I bought it from ebay and dont know whether someones connected a line level component to it such as a cd player. and if they had would it kill the phono stage...
Hi Big John
This is a nice reference series amp with a decent phono preamp stage. It is unusual to see a phono stage get damaged in this way.... but Murphy's law tells us "If it can be blown up, then someone will do it". I recommend that you do fix it. First up, perhaps check the settings for the preamp on the rear of the amp(from recollection). Be sure that you have it in moving magnet (mm) mode if you are using a MM cartridge.
Although its been a few years, My recollection is that there is a separate power supply for the phono preamp, with maybe even power regulators on on the actual preamp board. First check would be here to see if both DC rails are present for the phono Preamp stages. Most common failure here is heat stressed cracked/dry solder joints.
You need a good HiFi/Audio tech to have a look at it for you if the problems run deeper than DC supply for the preamp. Good luck. A FixYa rating is a great reward for my time to address your problem. Cheers
regards
robotek
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
